1analguy
A while back, someone posted a link to a BMW catalog of accessory parts specifically for the RTP. There was an LED tail/brake light (part number 63 17 0 446 858) that hangs right below the license plate on a bracket that fits underneath the plate and is held on by the plate screws. It has a wiring pig tail with a factory harness connector on it. A side note in the catalog says that bikes from July '07-on already have the necessary connection in the stock harness and that, for earlier bikes, a "wiring update kit" (part number 63 17 0 446 859) will be necessary.
My questions are: 1) Does "bikes" refer to all RTs, or only RTPs? And, 2) Has anyone mounted one of these lights on an earlier-than-July '07 RT? Specifically, will this setup work at all on my February '07 RT and if so, do I need the wiring adapter as well or do I need to fabricate something instead?
