awagnon
Member
I just bought a used 2006 F650GS with just over 7,000 miles on the clock. It really needed cleaning up, so I did some disassembly in the process. Inside the front chain sprocket housing were 3 or 4 small broken O-rings in the gunk which I assume are from the chain. Question: do I go ahead and replace the chain with only 7,000 miles on it? If so, should I replace the sprockets which look fine? Any advice would be appreciated.
