Results 1 to 7 of 7
Thread: Special tool for 1100RT Rear tire change?
    Question Special tool for 1100RT Rear tire change?
    Does anyone know if it requires a special tool to change the rear tire on the 1100RT. I have been told that it can damage the wheel if this is not done?
    DrPaul DrPaul's Avatar
    Apr 2007
    Bartlesville, OK
    Quote Originally Posted by Onebeemer View Post
    Are you referring to removing the rear wheel from the FD or removing/installing the tire on the wheel?
    DrPaul - 2008 K1200GT, 1973 R75/5
    2004 R1150RT - sold,1974 R90/6 - sold
    2002 R1150RT - sold,1987 K75S - sold
    Quote Originally Posted by DrPaul View Post
    I need to remove the wheel.
    No special tools, unless you consider a big-ass wrench and a 16mm (17mm?) socket "special." The bolts need to be torqued to 75 ft-lb when you put it back on. I go 50, then 75 in a crisscross pattern.
    Quote Originally Posted by JimMoore View Post
    Thanks for the info.
    OB
    Northern Front Range, CO
    actually, it sounds like the only "special tool" you need might be this: http://www.amazon.com/Clymer-R1200c-...9427522&sr=8-4
    Ride Safe, Ride Lots
    Apr 2004
    Warren Ohio
    You will need an adapter if you want to balance the tire\wheel. I got mine from Dennis Kirk http://www.denniskirk.com/jsp/tpl/pr...p282315&mmyId=
    01 R1150GS
    75 R75/5 Toaster LWB Red
    Al Navecky Jr
