marchyman
Cam Killer
but the rationale for a riding style that relies on "downshift-engine braking" over the use of the front brake just eludes me. And even more so if the bike has ABS.
I don't use "downshift-engine braking" over the use of the front brakes, but it is part of the braking process. Get on a 40 year old bike and ride it around for a while. You too will downshift, pop tendons squeezing the front brake, jump up and down on the rear brake pedal, drag your feet, and start looking for anchors to toss out.
Also, you might be forgetting about brake fade. That is a real problem with drum brakes. "Downshift-engine braking" helps lesson the braking forces which helps keep the drum cool which keeps the little brakes you do have working.
Not everyone learned to ride using modern equipment. Those who learned on the old stuff (or still ride the old stuff) may do things different for good reason.
// marc
