Page 1 of 12 1 2 3 11 ... LastLast
Results 1 to 15 of 179
Thread: Post photos of your vintage (pre-1970) BMW motorcycle
    Tucson, AZ, & Madison, WI
    1954 R68
    1954 R51/3
    1955 R67/3
    1967 R69S
    1967 R60/2
    1967 R60/2
    Jeff Dean
    Tucson, Arizona, and Madison, Wisconsin
    Co-founder, 1972, of BMW MOA -- http://bmwdean.com/r1200rtw.htm
    2017 R1200RT, 2019 R1250RT, 1967 R60/2
    Focused kbasa's Avatar
    Marin By God County, California
    1967 R60
    Dave Swider
    Marin County, CA
    Some bikes. Some with motors, some without.
    bensonhurst
    66 R60
    The fleet
    66 R69S
    Photobucket
    My other "airhead"
    1953 R51/3
    Another view
    1928 R52
    http://darryl.crafty-fox.com
    My baby
    Love this old girl... runs like a champ, has had great care over the years... original paint on the fenders and tank, some "touching up" and repaint of frame, etc etc. All in all, a real keeper!
    Bob Peckham
    Vero Beach FL
    1966 R50/2
    Where is that photo...?
    Sorry, cannot get photo to load...
    Bob Peckham
    Finally loaded the ole girl
    This is my 1966 R50/2.....glamour shot!
    Little Egypt Airheads
    Beautiful Southern Illinois
    Here's my '66. Almost finished with a basic resto. Needs fine tuning. Awful hard to get those carbs balanced, even with my $4 carb balancer tool!
    I visited the Sinsheim (Germany) Technical Museum last week and, among all the planes, trains, cars and bikes, I found this...
    Liaison 20774's Avatar
    Quote Originally Posted by lbrackr756 View Post
    How are you able to use the $4 tool on those early carbs? You must have a vacuum takeoff port specially machined into them. My /2 carbs don't have any such port...I've seen pictures of carbs with this done, but I'm not too sure I want to mess with original equipment.
    I bought a pair of special carb to head gaskets that had ports glued into them by the guy making and selling them. I think it was on EBay but not sure. They work but the suction on both sides agitates the oil in the gauge tubes so much that readings are almost impossible. Maybe I should use heavier oil in the gauge tubes?
    Interesting... I've heard people mention the bouncing of the liquid...I believe some kind of snubber or restriction in the lines is needed to reduce the pulsing. I have an electronic balancing unit, the TwinMax. It's a differential measurement system and shows when the two sides are not equal or a deviation from 0.
    Yeah, I'm thinking of a bolt shank with a small hole drilled thru it that's just the right size to slide up inside the hose on each side. This should restrict pulses but still let the gauge work. I'll let you know....
    Southern NH
    Put an adjustable needle valve in the hose close to the carb. As you close down the valve, it will allow less of the pressure pulse into the end of the tube containing the oil. There's a trade-off between having small pulsations and quick response to manifold vacuum changes.
    Aug 2003
    Marion,Ar.
    More pics please.
    I'm ready for more pics.
