Page 12 of 12 FirstFirst ... 2 10 11 12
Results 166 to 179 of 179
Thread: Post photos of your vintage (pre-1970) BMW motorcycle
  1. #166
    Aug 2003
    Marion,Ar.
    Early 60's /2 Bobber
    Built by Fred Bradley and on display at this years Ram's Rally.
  2. #167
    Front seat
    Good Morning, could you please tell me if the driver seat is a Corbin? If so their website says it fits the bike with the larger fuel tank, the one with the glove box on top. Tim
  3. #168
    Aug 2003
    Marion,Ar.
    If your talking about the /2 Bobber, just got to talking to one of the guys that that knows the bike. No it's not a Corbin. He says it's some type of Denfield/Pegusa covered in leather. That's what I know.
  4. #169
    seat
    Quote Originally Posted by rpeckham136133 View Post
    This is my 1966 R50/2.....glamour shot!
    Could you please tell me what brand seat this is? If it's a Corbin they claim they only make this style to fit with the larger of the two tanks that were available for that model. The smaller tank had the glove compartment on the side as yours does--according to them, the larger tank had the glove compartment on top. Tim
  5. #170
    Liaison 20774's Avatar
    Dougfur -
    Welcome to the forum! The picture you're referring to is from this post:
    https://forums.bmwmoa.org/showthread...l=1#post333851
    Unfortunately, that member hasn't been on the forum in nearly 3 years, so I suspect he will unlikely see this.
    But I have seen this Corbin seat on other /2s with the small tank as you suggest. It fits, there is a gap from the front of the seat to the tank and the nose of the seat sits up a bit. I understand from another forum that Corbin did some extra work for him to shave the nose a bit to lessen that effect. So, it can fit as is...if you like the look.
  6. #171
    photo of my 1967 R60/2
    I just bought this fine example of a well kept 50 year old classic, runs like a jeweled watch. Tim
  7. #172
    CENTEX USA
    Nice looking '67
    I have one, however, it's in a few pieces currently...money and time keep interfering
  8. #173
    I guess they're never done
    Added the period correct air filter and tail light.
    Looked high and low for that air filter housing, was found by my friend nearby his home in Munich.
  9. #174
    Fortes fortuna iuvat
    Quote Originally Posted by vechbmw View Post
    Here is an update of where things now stand. I have temporarily mocked things up in the frame to insure everything fit and worked. (Yes, this means both major components will have to be removed from the frame, again) I wrapped rags around the painted parts of the frame, to protect it from damage if I slipped, or bumped the frame, while installing the engine and gearbox.
    This view is of the bike's left side. The pin stripes are finished on the frame. The new Whittkopp leather saddle is mounted. Likewise the bottom end of the engine is finished, and the big nickel plated flywheel is on the engine. The large hole at the top of the case, is for the magneto, which I still do not have. But I have found one in Germany and it is on it's way!!!!!
    The foot operated clutch pedal and rod is visible, along with the external, open gear, kick start lever and clutch actuation bridge on the side of the two speed gearbox. Yes, it has an open primary chain that drives the two speed gearbox. The chain guard has not been fitted yet. The hand gearshift, (which passes through the gas tank) is mounted also. The lower end of the vertical gear shift rod, pivots in a bushing that is in the engine case. The cable that runs into the engine comes from the decompression lever on the handle bar. When you squeeze the lever, the cable pulls a free floating set of cam lobes, (which are slightly taller than the actual cam lobes) to lift both exhaust valves. Since there are NO WIRES or electrical system on this machine, the only way one can shut the engine down, is to hold open the exhaust valves, causing a loss of compression, making the engine quit.
    Attachment 57555
    This view is of the bikes right side. The drive pulley/clutch drum, with the brake brand, cable post, and attachment linkage, all hand made, (the brake was missing from the bike) is visible.
    Attachment 57554
    Yep, on weekends, some people watch TV, sleep, go shopping, but I work on my own motorcycles!
    Looking good. Any more progress over the winter months?
  10. #175
    Registered User vechbmw's Avatar
    Nov 2003
    Sturgis, MS
    Yes, I did finally finish the 1921 Victoria
    Time is fun when your having flies... I should have posted the photo long ago, but better late than never!
  11. #176
    Vech -
    Was the "fix" fairly straightforward after the maiden run in May 2017? It worked pretty good downhill!
  12. #177
    Nov 2003
    Sturgis, MS
    The fix on the victoria
    Vech -
    After I got the bike back from a museum that I loaned it to, for 6 months, I pulled the engine, and tore it back down. I suspected ring seizure, since I did not see any drag or galling marks on the pistons. I had reused the original pistons, and had the cylinders re sleeved. The rings on the original pistons were very narrow, and there was no true oil ring at all. So I had the ring lands machined out so I could use later KS modern rings. I suspected that the ring groove was not quite deep enough, and when the engine got hot, the piston expanded until it touched the inside of the rings, pressing them against the cylinder wall so tight it would try and bind and seize. I had the ring lands machined just a touch deeper, and I also had the bore loosened up just a little.
    I had other problems that I wanted to correct also. It seems the quality of the casting of the M2B15 engine is very crude compared to later BMW engines. After I put it together the first time, and had the engine installed in the Victoria frame, and I put oil in the engine, I discovered the casting was weeping oil through the pores of the aluminum in about 4 different places. This really irritated me, so I tore the engine completely down, and cleaned the crankcase, submerging it repeatedly in lacquer thinner (including putting the case in the oven at 225 degrees, to make it sweat the oil out of the pores). After repeated flushes, I painted the inside of the case with Glyptol and banked the cases in the oven to cure the red Glyptol coating. That did the trick. I now have the engine back together and back in the frame. But I have not run it yet. The paint, on the top of the gas tank (naturally) showed signs of bubbling up. So I took the tank back to the painters, and I'm still waiting....
  13. #178
    new owner
    Greetings all, I am the proud new owner of the R69S below:
    https://inventory.maxbmw.com/--xInve...ail?id=7276789
    I am awaiting delivery and will have a ton of questions I am sure, but wanted to introduce myself. I have never had a classic BMW (I had a 80's GS100) but did own a Nimbus for many years, sorely missed.
    Peace, Michael
  14. #179
    Welcome to the forum, Michael! That is surely a well appointed R69S. You're going to get many people coming up to talk to you about the bike!!
    I have one point to make...the ad says it's a 1963 model. According to the range of VIN numbers that I've been maintaining, the VIN should equate to a 1966 model. To verify, you can send the VIN info in an email to the BMW archives and they can tell you what they know about the bike and maybe have the build date. I have information in this thread:
    https://forums.bmwmoa.org/showthread...nd-Build-Dates
