Results 1 to 7 of 7
Thread: Front Brake sticking
    r1150gsp
    Unhappy Front Brake sticking
    I,ve got 2001 r115ogsp with 29000 miles on it .I've owned only about 2000 miles ,its a expolice bike out texas . I rode the end last summer & fall and got it out this spring and today rode to the blessing of the bikes in baldwin Mi. and on the way back the front brake start feeling kind of strange, like it was draging kind of , so I pulled in the clutch lever and it rolled to a stop the front brake was dragging petty good I rolled back and forth and seemed to release but if I use the front brake it does it again. When I put it up on the center stand and turn the wheel you can here the pads draging slightly . Any help would be great.
    Registered User brianfisk's Avatar
    Cromwell CT
    new
    Sounds like the pucks are coming out caliper. Your pads are worn. The pucks stick out and get hung up.
    Brian
    r1150gsp
    Quote Originally Posted by brainfish View Post
    Brian
    Thanks Brian , how thick should the pads be , I haven't removed them yet but looking in there with the trouble light they look to be 1/8 " plus .
    Urbana, IL
    Do the hand protectors on the 1150GS prevent the hand lever from going all the way out like on the 1200GS if it is not aligned properly?
    R1200GS LC Rallye
    Registered User godfather's Avatar
    Oct 2006
    Cadillac, MI area
    Bill, check the handguard, it may have gotten misalligned and is touching the lever a bit. With all those people milling around the bikes, who knows what may have happened. When you change the brake pads, be sure to clean up the pistons so they do not stick.
    Attitude is everything!
    08' V-Strom 650 great light weight tourer
    Jun 2005
    Green Bay, WI
    Could also need to have the brake fluid changed. There is a small relief port in the master cylinder that allows the master cylinder piston to fully retract. If that port gets blocked due to some form of contamination the piston stays slightly applied.
    Could also be dirt/grime/rust on the caliper piston/seals that is not allowing the caliper piston to fully retract.
    r1150gsp
    All right guys I took the bike down to Grand Rapids BMW friday morning and it was the stock rubber front brake lines, they replaced them with braided stainless steel lines and no more brakes sticking or dragging . I guess they diamante and cause the front brakes not to release. Thanks for the ideas guys.
    Bill
