Results 1 to 5 of 5
Thread: Nut blues.
    Capt. Grudo
    Mar 2006
    Stillwater Oklahoma
    Nut blues.
    While replacing the rear shock on my 1991 K75, I made a mistake and torqued the nuts to 77 ft-Lb. Two days later I discovered my mistake. I loosened the nuts and retightened them to 39 ft-Lb. My questions are:
    1. Did I damage the threads.
    2. Do I have to replace the bolts.
    3. If #2 is yes, how do I extract the lower stud and where do I get replacement nuts and bolts.
    Thanks in advance
    Doron Grudo
    BUDDINGGEEZER
    A bolt the size of the shock mount should be able to take 77 ft-lbs. If the bolt isn't broken and the threads aren't stripped I wouldn't worry about it. Sounds like neither is the case.
    Ralph Sims
    3 Red Bricks
    Jan 2007
    Pleasanton, Ca.
    Quote Originally Posted by BuddingGeezer View Post
    Ralph Sims
    +1
    LONG MAY YOUR BRICK FLY!
    Lee Fulton Forum Moderator
    3 Marakesh Red K75Ss
    Mine, Hers, Spare
    Capt. Grudo
    Mar 2006
    Stillwater Oklahoma
    Thank you. The bolt, stud and nuts look OK. It is always nice to hear from others.
    Thanks again.
    Doron Grudo
    Urbana, IL
    Ditto to not worrying about it, but the studs and bolts are available from BMW parts.
    My other bike is a BMW.
