Page 1 of 6 1 2 3 ... LastLast
Results 1 to 15 of 81
Thread: Generic oil filter
    Registered User ChicotDave's Avatar
    Jul 2006
    Bayou Chicot, LA
    Generic oil filter
    I have seen this posted before but I searched and could not find.
    Can anyone tell me the generic oil filter for a 2000 R1100R?
    One that can be found at Auto Zone or Walmart. Not many stores around here.
    Dave
    Keep a fire burning in your eye,
    Pay attention to the open sky.
    any testing that i have seen on "generic" oil filters says "don't waste your motor by trying to save a few bucks."
    beemerboneyard has Bosch filters ata really good price. Just buy a bunch, you'll be fine.
    http://beemerboneyard.com/boproilfioik.html
    kitze2
    Try Fram part #PH6063. I've seen these at Wallyworld.
    Here's the link. Ain't da internet great?
    http://www.power-21.com/HoneywellPow...cycle_1211.pdf
    BUBBAZANETTI
    i use the Purolator L10241 Pure One. they are tested as a good, well made filter. i usually order them on amazon.
    like i said- the Fram has tested incredibly poorly. many others are not much better-but hey, it's your dime.
    some tests:
    http://calsci.com/motorcycleinfo/FilterStudy.html
    or here-
    http://www.peterverdonedesigns.com/oilfilter2.htm (catch his comment on Fram filters about 1/2 way down the page, below the cutaways of the Bosch filters).
    jingdog
    I also use the Purolator L10241 with good results. Pep Boys has them on sale sometimes for $2.
    kitze2
    Where did you say this?
    I listed fram since wallyworld carries them. And since ChicotDave listed wallywolrld as a close retailer.
    I've seen the reports. I guess those millions upon millions of Fram filters out there are just ticking time bombs.
    But let's not hijack this thread with a best filter discussion. We all know where that goes.
    BUDDINGGEEZER
    Quote Originally Posted by kitze2 View Post
    The Fram 6063 corresponds to the Fram PH 3614. The Wal Mart super tec ST 3614 crosses to this and the Purolator filter mentioned and the Bosh. Champion filters makes the Bosh and Super Tec. Both have 98% single pass filtering. There is a web site were a guy dissected filters and the Bosh and Super Tec were identical. $6 or $2 your choice for the same thing. The Bosh and Purolators take a different wrench than the Fram PH 3614 and Super Tec ST 3614.
    These are the same filters used in the old K bikes.
    Some others
    AC Delco PF-53
    Amsoil ASF-57
    SMF122
    Bosch 3330
    72161
    Champion C301
    Fram PH3614
    PH3816
    PH6063
    Hastings 157A
    LF157
    Mobil 1 M1 - 102
    Motorcraft FL-271
    FL-793
    NAPA Gold # 1348
    Purflux LS188B
    Purolator FCO-201 (Obsolete P/N?)
    L10241
    ML 16825
    PL10241
    STP S3614
    WalMart ST3614
    Wix 51348
    51785
    Ralph Sims
    Jul 2006
    Bayou Chicot, LA
    I appreciate all the responses.
    WC Indiana
    some tests:
    or here-
    Fram buys the 6063 from the same manufacturer as BMW. You can compare the two, same size, finish, weight, internals look the same, just the writing on the outside is different. JON
    Quote Originally Posted by DarkCloud View Post
    Jon, do you have a link on that? i've read numerous reports, and the Frams always come up as crap, and the BMW & K&Ns (along with a few others) come up solid.
    I did a search in previous MOA threads on oil filter tests. here's what i came up with- http://www.tobycreek.org/oil_filters/kandn.shtml This is one that i had remembered reading before.
    when you look at the pics and the write-up of the BMW OEM and the Fram, they are clearly NOT the same filters! Getting a filter cheaply and readily should not be the only criterion for filter selection- somewhere in there you/we should be paying attention to quality of product as well.
    Focused kbasa's Avatar
    Marin By God County, California
    When you've spent several thousand dollars (at minimum) on a motorcycle, it seems kind of lame to try and save $2 on a filter at the potential risk of toasting your motor.
    But hey, that's just me.
    Fram:
    BMW:
    Dave Swider
    Marin County, CA
    Some bikes. Some with motors, some without.
    BUBBAZANETTI
    Mahle makes BMW filters. I can find no link, online or elsewhere, between Mahle and Fram.
    the pictures provided by Dave are all the proof any of us should need.
    Mongo
    This seems like a pretty good write up on oil filters. It is written for non engineers like me.
    Oil filters
    This cross reference guide is also pretty good.
    Rally Rat Slablog's Avatar
    Woodstock, Georgia
    Could you detail those results for us please.
