Results 1 to 8 of 8
Thread: intermittent gear slippage
    On the Road
    Jul 2007
    Land O' Lincoln
    Greetings. I recently acquired another 95' K75 with what looks to be very low mileage (30K). I am experiencing intermittent gear slippage from 1st gear into neutral. All the other gears are tight. Any suggestions as to where to start trouble-shooting would be greatly appreciated.
    Quote Originally Posted by vroomhilda View Post
    Greetings!
    Question - can you describe this a bit better?
    If you mean it pops out of 1st into neutral - under what conditions does this happen?
    You might have a worn shift drum, or you might need a slightly different shifting technique to keep it from happening.. better description of the problem would help..
    On the Road
    Jul 2007
    Land O' Lincoln
    The slippage occurs when throttling up for the next gear shift. There is nothing really special or unique about the conditions surrounding the event that I can think of to describe. I would definitely describe it as "poping" out of gear.
    I don't quite understand "throttling up for the next gear shift" (I'm slow on Thursdays sometimes..) Do you mean when accelerating in gear before up shifting?
    If so - sounds like bent clutch forks or worn shift drum.
    Do make sure your toe isn't doing it - I have known people who had their toe under the shifter getting ready to shift and actually were putting a bit of pressure on the shifter without knowing it. You could try moving your toe to the footpeg and try to reproduce the actions that cause the jump out of gear.
    On the Road
    Jul 2007
    Land O' Lincoln
    On the Road
    Jul 2007
    Land O' Lincoln
    yes - accelerating in gear before up shifting. I will pay extra special attention to the position of my shifting foot and will definitely employ your foot to foot peg idea to try and replicate the event. Hopefully it is just a case of user error. I have been know to make a lot of them. thx for the great advice. I will post my findings.
    when i first bought my K11RS, it would jump out of gear (from 2 to N) after an upshift, soon after i began the acceleration. turned out to be my fault, in that i just wasn't being firm enough on the upshift. (and that was after 70K miles of K75 riding. go figure!)
    Astatula, FL
    Aside from basic technicque, there may be other factors that can cause this. A new pair of boots with a different thickness sole will change the position of your foot on the peg in relation the the shifter. New footpeg rubbers will do the same.
    Bob Weis
    Bikeless! 2004-bmw-k12rs-hannigan-Sold!
