Results 1 to 10 of 10
Thread: Need some trouble shooting help
    Registered User LCampbell's Avatar
    Nov 2006
    Vacaville Ca.
    I have a problem with my 99 R1100RT (62500miles) that seems to be temperature related. In the morning when it's cool I depart on a 2 hr or so ride the bike runs smooth & strong at all rpms. I stop,have lunch & hang out a bit & then get back on the bike and whenever I increase the RPM above 3500-4000 in any gear it gets very buzzy. The mirrors are a blurr. & the vibes in the bars is very noticable & the bike seems to be down a little on throttle response.
    The bike has had the 0/0 TPS adj. & Autolite 3923 plugs
    Things that I have checked:
    Valve adj. a couple of times. Changed plugs a couple of times. Rechecked TPS adj.
    Checked plug wires & coil with an Ohm meter (Readings verified by the guy at Beemer Boneyard. Checked TB sync several times/ Did off idle sync at 4000RPM
    I checked the Outside Air Temp sensor with an ohmmeter & it seemed to be within the specs that that I found on another Forum. I also checked the computer for fault codes with an analog voltmeter / counting the blips & had an OAT sensor fault. Which has cleared & hasn't reoccured. I have ordered another OAT sensor and am awaiting its arrival.
    I just finished replacing all of the throttle cables (4ea.) No pebbles in bellcranks.
    Any help diagnosing this problem would be greatly appreciated.
    Northern Front Range, CO
    stab in the dark- but i just replaced the alternator belt on my bike, and found that afterwards it began running significantly smoother. possibility?
    Ride Safe, Ride Lots
    Nov 2006
    Vacaville Ca.
    Thanks. I changed mine a year ago. But I can take a look at it again
    Jun 2007
    Brownsburg, IN
    Could it be a coil starting to go south?
    Nov 2006
    Vacaville Ca.
    Any thoughts on how to check a coil out other than the standard ohm meter check? Would it do any good to heat it up with a heat gun & then check the resistance????????
    Registered User ALIENHITCHHIKER's Avatar
    Oct 2004
    Asheville, NC
    Quote Originally Posted by LCampbell View Post
    I've always understood that coils need to be checked when they're hot (Though I've never needed to check one - so I am NOT the voice of experience).
    It does seem reasonable though to check the resistance with it cold, and then warm it up by degrees, rechecking at intervals to look for a rise in resistance.
    Could a heat gun potentially get it too hot - I mean, hotter than its usual operating temperature?
    Your diagnostic thinking seems to be on track. The only other thing that comes to mind would be a possible air leak, either at the intake or exhaust end, resulting from a poor seal that malfunctions after things really heat up, causing the effected cylinder to run lean.
    The coil sounds like a likely culprit. Keep us posted.
    Steve
    Current Hottie: '00 R1100RT
    Old Flames: '85 K100RT, '80 Yamaha XS850, '67 Triumph Bonnie, '66 Honda 90 Scrambler
    Nov 2006
    Vacaville Ca.
    Quote Originally Posted by alien_hitchhiker View Post
    Thanks for the imput. I'll ck for intake/ exh. leaks and maybe try heating up the coil a bit & check the resistance as I go.
    Slow & Easy
    Dec 2005
    Austin, Tx
    I have a 2004 R1150RT and it is the basis of my knowledge. It is my 1st oilhead. Could it be your bike could be going thru another phase of wear in?? My suggestion is to sync your throttle bodies where the vibration is its worst and see what happens. I've found on mine I have to use two high velocity fans on the engine to get a good sync at running temperature. It really makes a difference. My bike at 56K miles is just about as smooth as glass from 3.5k up to 4.8k rpm.
    Dave Faria
    Austin, Tx
    Nov 2006
    Vacaville Ca.
    Quote Originally Posted by Dave_Faria View Post
    Dave Faria
    Austin, Tx
    Thanks Dave. I have mine bike synched at approx 4000 RPM which is in the range of the buzzing. To me it seems to be a heat issue. It will run smooth as glass & strong in the morning but be buzzy/not quite as peppy in the afternoon
    temp related performance issues can also be the HES on its way out; you might want to look at that as a possiblity.
