Results 1 to 3 of 3
Thread: Installing rubber knee pads on gas tank
    Registered User Bullett's Avatar
    May 2007
    Southern Oregon coast.
    Question Installing rubber knee pads on gas tank
    Is there any specific trick to putting the rubber pads on an old /2 tank?
    I'm wondering if I should use tire lube;
    Or start with the large end or the small end.
    Anyone care to share a tip or two?
    bensonhurst
    Put them in HOT water first, it should be easy then (while they're hot)
    Oct 2003
    I agree about the hot water, or, leave them out in the sun for a good while.
    I usually start with the pointy (ish) end and then work my way up both sides. Take your time and just work it carefully.
    http://darryl.crafty-fox.com
