Results 1 to 15 of 18
Thread: Anyone using Odyssey Battery PC680?
    Registered User skidgillen's Avatar
    Sep 2007
    South Dakota
    My 4 year old wet battery is on its last leg. On cold days (45 F) it barely turns over fast enough to start it up. I pulled it out, added distilled water and charged it back up, but nothing changed. I am looking for input on the Odyssey battery, pros and cons, as the replacement.
    Skidgillen
    Black 2002 R1150R abs
    "I tried being reasonable, I didn't like it." Clint Eastwood
    pc680
    i just got one when my westco give up the ghost. mind is for the 1985 R80RT.
    i would think a litle small for the oilheads. sure zipps the aithead over. you might want to go to the odyssey website and see the application chart. you didn't state what it was going in?
    Quote Originally Posted by hardbargin View Post
    sorry but i cannot spell correctly. not my best ability typing.
    Northern Front Range, CO
    approaching 2 years on mine. works great if i keep it on a Battery Tender.
    Ride Safe, Ride Lots
    83R100RT
    Battery
    I understand that a Oddessy 925L will fit.
    Quote Originally Posted by 83R100RT View Post
    maybe yes, and maybe no. The 925 is not spec'd by Odyssey for any oilhead, only airheads and some earlier K (K75 & K100) models. not knowing what skidgillen is riding (hint: update your profile!), it would be tough to say what will or won't fit (tho because he posted in "oilheads" i'd make a wild guess that he's probably on one of them. the PC680 is spec'd for all oilheads.
    ArthurKnowles
    The PC 680 is what I see recommended for the R1100RT, R1150RT, K1200LT and I didn't check the R1200RT but suspect it is also recommended for it. When my Westco battery fails in my RT or whatever I have in my LT fails I will move to the PC 680.
    Raspberry waffles Bob!!! kewlmoose's Avatar
    Jan 2007
    SE Wisconsin
    Pc680
    I put one in my 02 R1150RT last summer & it's been working fine. I kept it on a battery tender during the (realllly long) winter this year and it started the bike even when it was 20 degrees with no problem.
    Jul 2006
    Haltom City, Tx
    I have a PC 680 in my '95 RSL, and I'm very pleased with it.
    Robert
    Registered User REBGEN's Avatar
    May 2007
    Clive, IA
    I'm in my third year with a PC 680 running strong in my R1200C. I too keep it on a BMW gel tender with great results. ABS faults are a thing of the past.
    98 R1200C Canyon Red
    Sep 2007
    South Dakota
    2002 R1150r
    Yup, its an oilhead, a 2002 R1150R. Now does the Odyssey need a special battery tender? I have a EverStart (Walmart) 1.5 amp trickle charger that has float mode, and will not charge above 14.4 volts.
    Skidgillen
    jduke
    I've had a PC680 in R1100S for over 3 years now and it's great. No water to check, almost plug and forget.
    Now watch mine die this weekend....
    NORSMAN
    I replaced my stock bat with a pc680... it's been really nice on cold camping mornings.
    Great battery and does not require constant charging either. Test like the instructions and charge like they tell you to, to avoid damaging it and they work as advertized. Kind of pricey to buy though so far so good after a year and a half. Only time will tell if it outlasts the stocker though.
    ArthurKnowles
    Best price
    The best price I've found is $117.00 at Aerostitch. Page 222 in their 2007 catalog they mailed me.
