D
dave2large
Can you bolt up a set of 1000CC cylinders & heads to a R80 bottom end?
I'm curious how you came to that conclusion?it's kind like a /7 with more low end but less top end speed.
I would think the top end is lower, because you are still using the R80 lower geared rear end
What then is the other half of the equasion?Most R80 to R100 conversions are just half done.
So, if the 1979 R80 came to the US originally equipped with a 1:3.20 rear gear set, then what final drive ratio would you recommend as a better match for an R80 to R100 displacement change?
