Page 5 of 6 FirstFirst ... 3 4 5 6 LastLast
Results 61 to 75 of 81
Thread: Generic oil filter
  1. #61
    Loose Cannon flash412's Avatar
    Northern Colorado
    BMW has OFFICIALLY approved using ANY filter from ANY manufacturer in their motorcycles under TWO conditions. First, you must send a payment of $20 for each non-Roundel marked filter you install on a Roundel-bearing vehicle. Note: This is not a one-time charge, but must be paid at EACH filter change. Second, you must sign a release that relieves BMW from any warranty responsibility whatsoever, INCLUDING the engine and rear differential.
    Click here for Tales of Motorcycles and Life
    - BMW MOA Lifetime Member #18854
  2. #62
    jingdog
    Quote Originally Posted by flash412 View Post
    Gee I guess I owe them $400.
  3. #63
    erickson9502
    Filter again
    Some people do not have dealers 2 blocks down the street. Try 250 miles. Please do not tell me to go to Bob, Fred, Dave, Jack BMW and order online. Some folks just want to go and pick a good filter at the auto part store.
  4. #64
    Northern Front Range, CO
    and why not go internet shopping?
    Ride Safe, Ride Lots
  5. #65
    Quote Originally Posted by GlobalRider View Post
    Nice pics!
    As similar as they look with a few differences, I wonder why the BMW filter feels so much heftier.
    alex, can you not see the filter core of pleated paper that is about 2x as dense as the Fram filter? think maybe there's a good part fo the weight?
  6. #66
    Canada and the Alps
    Yes, I've noticed that. Also, more surface area makes for a longer lived filter.
    But filter media is lightweight and doesn't really add to the weight worth talking about.
    Notice the filter media end caps though. The ones in the BMW filter are more substantial and are metal from what I can tell. The Fram filter media seems to be bonded to what looks like a cardboard end cap.
    As for the BMW filter element, an O-ring (not shown) would need to sit atop that metal end cap and it looks like there is a groove for one. It would create the seal between the "in" and "out" going flows of the oil filter mount. The BMW spring would keep the filter pressed against the seal from the looks of it.
    I would assume the bottom end caps of both filters would have a by-pass valve.
    A BMW oil filter I just peered into also has a plastic plate within the filter element. I wonder what its purpose is?
    There is no question that the Fram filter, as far is construction quality is concerned, is relatively cheap. Remember Fram's "Pay me now or pay me later" slogan? Sort of like Ford's "Quality is Job 1" slogan. When you have to advertize it..well you know the rest.
    Maybe KBasa can get into the material and construction details, if he is the one who split those filters and took the pics.
  7. #67
    Focused kbasa's Avatar
    I got those photos off a site where a guy was comparing oil filters. http://www.tobycreek.org/oil_filters/
    Worth reading, IMHO.
    Dave Swider
    Marin County, CA
  8. #68
    Canada and the Alps
    Quote Originally Posted by KBasa View Post
    Thanks!!!
    Sure enough and I quote...
    "If anything, the Fram will show you how NOT to build a high performance oil filter. Notice that the endcaps are cardboard".
  9. #69
    Thanks!!!
    It appeared to be the only manufacturer that used cardboard, as well. In the text, the author describes a Fram failure that resulted in bits of cardboard floating around in the engine of his car.
    Dave Swider
    Marin County, CA
  10. #70
    Registered User brianfisk's Avatar
    Cromwell CT
    filters
    I guess I am in trouble my motor is going to blow up. !97,000 miles(97 R1100RT) and I change my oil when my lazy a?? gets around to it. Somewhere between 4500 and 6500 miles. What type of ridding I do and I always chage the filter. But the last 7 or 8 times I have used a NAPA gold the same one that goes on my PT Crusier. The fit is not perfect the sealling ring is a bit smaller. Works and I did cut one apart and did a compare. $12 cheaper. Around 35 oil changes on this bike, so 7x12 = $84 saved. Not much but almost a tire.
    If I did 3,000 mile changes it would be even a bigger savings.
    Oh I also cut a FRAM Filter from my car, hence the NAPA gold.
    Brian
  11. #71
    Canada and the Alps
    In the text, the author describes a Fram failure...
    What worries me is that Fram was Allied Signal which is now Honeywell...which is the filter that I get at my local Honda dealer for my CR-V. The original oil filter that came off the car was far more substantial and also made in Japan.
    But proof is in the mileage. I'm coming up on 100,000 miles and the cam lobes still look like they just came off the shelf. And that with sub-zero starting temps running Mobil 1 since the first inspection.
    If one is really worried, mount a CM Filter (formerly Mecca).
  12. #72
    WC Indiana
    Is that a Fram 6063 in the cut away picture? No its not.
    Physically compare the Fram 6063 to a BMW filter. Put a new Fram 6063 in one hand and a BMW filter in the other. Then tell me what the difference is besides the writing on the filter.
    JON
  13. #73
    Canada and the Alps
    Quote Originally Posted by DarkCloud View Post
    JON
    I don't think Fram makes that filter; they buy it and re-label it. Something I once read...whether its true or not, I don't know.
  14. #74
    Registered User MOTOR31's Avatar
    Aug 2006
    Full timr RV'er, where we park is home. No fixed address or location.
    I'm curious why a metal cap on the end of the filter media would be better than a "cardboard" end cap. In both cases the glue is what bonded the end caps to the filter media. If there is a glue failure, both filters would perform the same. If there is no glue failure both filters perform the same. The media itself is a type of "cardboard" in both cases as well. If the "cardboard" were to fail it could fail in any of the pleated areas just as easily as it could at the end of the filter media. This is assuming that the micron filtering specs were the same for both filters.
    DEFINITION OF A VETERAN A Veteran - whether active duty, retired, national guard or reserve - is someone who, at one point in their life, wrote a check made payable to "The United States of America", for an amount of "up to and including my life."
    Author Unknown
  15. #75
    JON
    Since a stamped cover is a stamped cover, I'd suspect the only way to tell would be to saw a couple of them in half. Anybody have access to a band saw?
    Dave Swider
    Marin County, CA
