I think I'll get an old slash [something] with a slinger, so I don't have to buy oil filters.....![]()
Rinty
Rinty
I remember some years ago an article on oil filters for Porsche 911 engines (which have dry sump systems). Even though all of the filters looked essentially the same on the outside and would fit the oil filter mount, when they cut the filters open, they found many differences inside. On one filter, the oil flow direction through the filter was the opposite of what the dry sump system requires (the Porsche oil system flow is reverse of the usual filter flow direction). Bottom line - until you know FOR SURE that the oil filter you want to use is at least equivalent to the factory recommended oil filter, stay with the factory oil filter.
Of course, as someone below said, it's your engine.
Mike White
MOA Life Time Member #57882
'13 K1300S "30 Years", '95 R1100RS, '88 K75S, '97 Ducati 916, '95 Ducati 900SS CR. Gone, but not forgotten, '75 R90S
(modified) i suspect that pretty much all of us could say exactly the same thing about whatever filter we have been using for however many years.
but wouldn't you just HATE to be the first one to report that "I used filter XYZ to save $3.00, and it roasted my engine!"
Ride Safe, Ride Lots
Mike White
My 74 Beetle didnt even HAVE an oil filter and the bearings, lifters, oil pump etc lasted 250,000 miles. PLUS it only had 2.5 quarts of oil in the sump.
Mike White
i would say dozens of long distance rider's and several well respected oilhead mechanic's opinions are all the reassurance i need for the above mentioned Purolator. not to mention plenty of "oil filter" tests that they passed with flying colors.
i went with it over stock because of its high degree of "recommendedness" and relative "cost effectiveness".
Well, I guess that means you feel you KNOW FOR SURE that the Purolator filter is at least equivalent to the BMW filter. Heck, if they only cost $2 or so (from an earlier post), I may buy one and cut it apart just to see what it looks like inside.
Always looking to save a little money . . . as long as it's smart money.![]()
Mike White
The cheapest thing on a BMW...
Stephen Burns - 2007 R1200GS
BMW MOA Lifetime Member
www.burnsmoto.com GS911 WIFI BMW Motorcycle Diagnostic Tool
I just checked Purolator's web page. Correct if I'm wrong here.
The PL10241 oil filter seems to be a PureOne automobile oil filter (nothing inherently wrong with that) that just happens to have the same threads and is about the same physical size as the BMW motorcycle oil filter. From Purolator's web page, the Purolator BMW motorcycle oil filter is ML16825, which is "only" a Premium Plus filter. It looks like the PL filter is slightly longer and has a slightly smaller OD than the ML filter. The ML relief pressure is 14 psi and the PL relief pressure is 12-17 psi.
Mike White
The premium Plus L10241 fits the same filter wrench as the BMW filter (76mmX14 flute) I believe the PureOne is the same size.
