pglaves
#13338
Paul, Jim, Dave, Don, et al,
How about spline lube on the Hexheads? Are people seeing the same need to tear half the bike apart to lube the splines on those models, or has BMW made some improvements that make them more "maintenance friendly?"
Paul - would you still recommend a 50K teardown on a Hexhead to check/lube the splines?
Thanks,
That is like politics, or sports. Too early to tell and too close to call. I hope they don't need it, but I'm not holding my breath. Time will tell.
At one point in its history BMW started nickel plating parts, and declared that the spline wear problems which had been evident in earlier bikes was cured (or at least most of the dealers made such declaration). Of course it wasn't and owners who believed it - and kept their bikes 50 or 60 or 70K miles learned otherwise the hard way.
At the seminars I have done for the last ten years the need to lubricate clutch splines has been historically the most argumentative topic we have covered. (Until 140wt gear oil in final drives came up for discussion). People just don't want to believe that this lubrication is necessary. I've heard almost every "My old Ford" and "My Toyota" story possible - as to why we don't do this to cars so I don't have to do this to my motorcycle.
I don't fully understand - other than to say the size of the splines and the metallurgy is different.
What I do know from taking a lot of transmissions out of bikes is that they splines need periodic lubrication and periodic lubrication helps them last a very long time. I quit arguing with people at my seminars. I just tell them "lubrication is my recommendation - it's your bike - do what you wish."
