Results 1 to 10 of 10
Thread: Front wheel Bearing assembly help
    Qualified Fecal Stirrer KBikeKev's Avatar
    Apr 2007
    Grafton,WV
    Nuts, I just got the three spoked wheels back from the powder coater (sliver metalic) and they look really nice ,but now I need to reassemble the front wheel bearings and I think I remeber how they go back together, but it just doesnt' look right.
    Isn't it ......
    1. clip ring
    2. large bearing (Smooth side of wheel)
    3. spacer
    4. skinny bearing (Hollow side of wheel)
    I am not at home where I could look in a book right now. I would like to get these in before I leave work.
    Thanks for any assistance
    Kevin Wood
    MSG U.S. Army, Ret.
    BMWMOA 131753, ABC 129393
    99 K1200RS, 71 R60/5, 85 K100RS - SOLD
    mrich12000
    Arrow
    Sent you a email
    for others duing the same read this thread
    http://www.i-bmw.com/showthread.php?...wheel+bearings
    Apr 2007
    Grafton,WV
    TMI, I just need the order of parts assembly, That is not mentioned in that thread, but just about everything else is.Thanks though!
    Kevin Wood
    MSG U.S. Army, Ret.
    3 Red Bricks
    Jan 2007
    Pleasanton, Ca.
    Order:
    1. Lock Ring
    2. 16mm bearing
    3. spacer
    4. 12mm bearing
    Look at Parts fiche at Max BMW:
    http://www.maxbmwmotorcycles.com/fic...p?mospid=47861
    under wheels
    Also, I found some more badges for you. Check other thread.
    LONG MAY YOUR BRICK FLY!
    Lee Fulton Forum Moderator
    3 Marakesh Red K75Ss
    Mine, Hers, Spare
    Apr 2007
    Grafton,WV
    Thanks, I did look at Max earlier, but just wanted to confirm. Eventhough the price difference was an indicator of the size difference on the parts fiche, it is often many times not the case. I love Max BMW they always put M&Ms in my order!
    I feel confident to let the guy with the press work his magic now, thanks again.
    Kevin Wood
    MSG U.S. Army, Ret.
    Urbana, IL
    Quote Originally Posted by kjwrad View Post
    Not the price, but the bearing sizes are given in the text.
    R1200GS LC Rallye
    Apr 2007
    Grafton,WV
    Ooops, my bad, I saw that (25X47X12) and (25X47X16), but didn't realize that it was refering to any knid of size measurement. Thought it was just some other type of refence or part number. Thanks, Learning has occurred.
    Kevin Wood
    MSG U.S. Army, Ret.
    3 Red Bricks
    Jan 2007
    Pleasanton, Ca.
    Possibly too many of the BLUE M&Ms?
    Stick with the RED ones. They are much better for you.
    But make sure MAX doesn't throw in any of the PURPLE ones with the next order or you'll be up all night.
    The YELLOW ones are pretty cool too.
    Mine, Hers, Spare
    mrich12000
    I like the red ones
    Apr 2007
    Grafton,WV
    This thread is done
    Thanks for all the help. The wheel is back together and all I need now is the Me880s to go on next. (next paycheck, or so )This thread can be closed or deleted or what ever happens to the ones that no longer have any relevance. thanks again to all those that provided such usefull info.
    Kevin Wood
    MSG U.S. Army, Ret.
