Results 1 to 15 of 18
Thread: Handle bars Risers
    Registered User coyotebmw's Avatar
    Feb 2004
    Newcastle, WA
    Handle bars Risers
    I am looking at moving my bars back and up to create a more comfortable riding position. I have been on the F800Riders.org site and found the "SW-MOTECH top clamp" system. Does anyone have any experience with these? Any recommendations out there?
    CoyoteBMW
    53 years of BMW's - 1960 R26 and 2007 F800ST!
    old fa_t 110593's Avatar
    Nov 2006
    Boerne, TX
    Risers
    The best on my GS and ST. The ROXspeedfx.com look them up $74 !!!! They are great and at the cost !! Joe
    J Fisher
    R1200RT
    R1200GS
    JREDFORD131730
    I put them on my 2005 R1200rt before I went to Alaska last summer. They seemed to make the ride more comfortable, not stretched out as much.
    sapphire
    Quote Originally Posted by coyotebmw View Post
    If you put them on, let us know how they are for you. I may do that for my f800st, but will wait awhile before I do so (at least the 600 mile first service...ha ha). I think my bike might be okay, but haven't had a chance to take a long ride yet because of the weather and I am always interested in what others think of comfort modifications.
    Feb 2004
    Newcastle, WA
    Delay on putting them on
    I did purchase the "SW-MOTECH top clamp", but when I went to put them on realized that having ABS brakes required some control cable changes. I have delayed this activity until I can work with a shop to have it done right. I am still looking forward to installing and using them, but need to work out the cable issues first.
    CoyoteBMW
    buzzez
    FYI, Bar backs don't work on the 08 F800ST's unless someone can figure out how to lengthen the brake line.
    Feb 2004
    Newcastle, WA
    That is what I am finding
    It seems that yes there is a problem with the cable lengths, especially if you have ABS. I have a shop that does a lot of work for me on my BMW's and they said they can get new cables made. Seems BMW really doesn't give you a whole lot of extra cable, or in the case of the ABS, extra tubing length to set back the handle bars.
    CoyoteBMW
    Unavailable for comment
    Apr 2007
    Wolverines released
    Have bar risers on my Funduro but not my CS. The bar risers make the bike a lot more comfortable and so I'll be adding them to the CS. I think new cables will have to be made as I have ABS on the CS and it looks like there's not much allowance in the cables to add height.
    Really, I can't say enough good things about the risers on the Funduro. It makes a lot of difference in comfort.
    100,000+ miler 32232's Avatar
    Southwestern Ontario
    Instead of bar backs I put a set of R1150R bars on my F800ST. A bit more rise and pullback than the risers, without (IMHO) the Rube Goldberg appearance. My dealer specked a lengthened Spiegler front brake line for me, and the whole setup is indistinguishable from factory issue.
    Dave
    Quote Originally Posted by Buzzez View Post
    Nope. Look at the link with instructions I posted in the message prior to your response. I'm happily buzzing along with risers and stock lines with no issues.
    -A
    Again, unnecessary. My bike has ABS. Follow the link I posted for rerouting instructions.
    -A
    Feb 2004
    Newcastle, WA
    Go them on
    Aether's process worked.
    Quote Originally Posted by Aether View Post
    I had a shop do it and it went very smooth, except they missed the tie wrap part on the Clutch cable. Had a very "tight" clutch for a while until we figured out that you need to tie wrap the clutch cable to keep it from slipping up on the ignition assembly.
    I has made a big difference already. The reason I needed set the bars back was an tendonist problem in my right elbow and now there is no pain when I ride.
    Aether, thank you.
    CoyoteBMW
    Apr 2007
    Wolverines released
    I believe that's what is on my '99 F650. Last night, I put on hand guards and the heated grip kit and there was plenty of room for the wiring.
    My F650CS has ABS but no risers. I like the F650's risers so much that I'm going to put them on the CS and yes, it looks like I'll have to change the brake lines for the risers.
    Herleman
    I just came in from installing the SW-Motech risers on my 07 800 ST.
    It took about half an hour, including the time it took to find all of the proper tools.
    I moved the brake line to the back of the fork and it fit almost perfectly.
    The electrical wiring run on the right side is tight, but it fits.
    I've got to get it on the road to tell if the handles and the bar is in the right position, but that's a minor issue.
    One positive in the whole thing is that the mirrors seem to be less covered by my arms.
