After my last ride I discovered brake fluid all over my rear wheel and right side case. Closer inspection suggests the hose has separated from the crip connection next to the caliper. Replacing the hose looks fairly easy, but I just started doing my own maintenance on this R1100RT(with ABS), and I am somewhat concerned about how to bleed out air from the system once I replace the hose. Do I just treat it like a brake fluid flush?
