Results 1 to 12 of 12
Thread: Seeking comments re: jesse rear compartment
    WesPeterson
    I'm looking for some feedback (i.e., happy/sad you bought it) from anyone that has purchased the al jesse rear compartment or rear rack. The compartment is $30 more than the rack and has, well, a rear compartment.
    WesPeterson
    Wes,
    Just had to say that yours is a brilliant post. Pure poetry - and funny too! Keep up the good work!
    WesPeterson
    Originally posted by Wes
    Wes,
    Thanks Wes. I appreciate your noticing my brilliance (you seem pretty smart too). That being said, be nice if you had some input into my question.
    Focused kbasa's Avatar
    Marin By God County, California
    Time to dial back the caffeine, Wes?
    Dave Swider
    Marin County, CA
    Some bikes. Some with motors, some without.
    Kool Aid Dispenser! jimvonbaden's Avatar
    Mar 2004
    Alexandria, VA
    Who is Jesse and what does a "rear rack" look like?
    Jim
    WesPeterson
    My evil twin Earl momentarily hijacked my computer - all is ok now.
    On the Road CGARR's Avatar
    Dec 2003
    Alaska
    Wes,
    I just added a Jesse rear compartment this past weekend........ mostly to mount the Jesse top box I also added. So far they have been fantastic on the road.
    The top box fit and finish was great, but you do have to line up and drill the holes to mount it (so you can have it open in your own favorite choice of directions). That took some time. The rear compartment came ready to mount, and went on in less than 10 mintues (assuming you have the right allen wrenches). The only real issue I have with it, is the door for the rear compartment, it seems to be installed at a slight angle, and with the top box in place the door rubs the bottom of it as it opens. It will be a quick fix with file, and a touch of flat black paint, but for the cost I expected better than that. Having said that, it is possible it is just one of those not quite perfect units that happen from time to time in any manufacturing environment. If you like the look, and you have the $$$ to spend, they are nice to have, and if all you are adding is the luggage rack on top, then the installation should be trivial. Bear in mind that the rear compartment is open topped, and intended for use with a rack or a top box. Without one or the other, there is no top to the rear compartment.
    WesPeterson
    Excellent write-up - thank you. Your last point (which I've quoted) is not obvious from Al's web-site. Thank you for pointing it out.
    Jesse Rear Compartment
    I just bought one, to go with a full set of Jesse side bags & top case. The rear compartment now comes with a top welded in place. This makes it more secure but harder to install. The instructions for all Jesse products are crap. You have to infer steps and I think things have changed from whenever the instructions were created because my R 1200 GS is different from what the instructions assume.
    Pismo Beach, CA
    Wow! A 9-year 2-month BUMP!!!
    ... is this a record?
    Lew Morris
    1973 R75/5 - original owner
    1963 Dnepr
    I respectfully disagree. At least with the instructions on the current, LC GS. I just installed the pannier mounts and the installation instructions were clear to me. I agree though, much better than they were in the past (had old style Jesse bags on my 08 GS).
    Quote Originally Posted by Glenn85 View Post
    Warmest regards,
    Doc Reid Hester
    Wondering about your drinking? Consider our FREE Drinker's Checkup
    Get saddlesore when riding? Check these shorts out
    Utah
    Who is Jim VonBaden, and what is he doing in this thread?
    Oh, no, I mean, Wes, I was thinking of getting one of those Smugglers. From Corbin. I think those are nice looking, but they replace the rear seat. And, on rare occasions, I need the rear seat.
    I still don't see much on the Jesse, but it looks like a top box.
    Wes. Wes. Are you there?
    Ladies and gentlemen. Wes has left the building.
    dc
