Results 1 to 4 of 4
Thread: front rotor movement
    hi, my 2010 r1200rt with 43000 miles has movement on both front rotors. i can move the rotors forward and back maybe 2mm. no noises or braking issues. i have read about worn mounting buttons, could that be the issue? is this an issue?
    CENTEX USA
    Welcome to the forum
    No problem...you have semi floating rotors. The worn button issues were more of a 1100 Oilhead and early K bike issue.
    The early 1200's had fixed rotors and zero play.
    thanks for the info, the rear tire rotor has no movement is that a none floating type?
    CENTEX USA
    Yeah, the rear rotor directly bolts to wheel mount flange and zero float.
  1. Front Rotor Rivet Issue
    By riefstahl in forum F-Twins
    Last Post: 02-29-2016, 01:39 PM
  2. 96 R11RT Front rotor Q.
    By brewmeister in forum Oilheads
    Last Post: 03-14-2011, 08:45 PM
  3. Front Rotor Bolt Recall
    By Bullett in forum F-Twins
    Last Post: 02-27-2011, 12:51 PM
  4. Front rotor replacement
    By 85343 in forum Oilheads
    Last Post: 04-14-2007, 02:50 AM
