Not really carefully evaluated the brakes yet. The fluid is dark in both systems. The front brake works but the rear does not seem to grab at all. I plan to tackle the brakes this weekend. I imagine I may need to remove the rear caliper and force the pucks back into their bore then flush. I'm pretty experienced with brakes and have done the control and wheel circuits on my R1150RT several times. This K75 system is sooooo much simpler. Thanks for the reminder!Congratulations Paul. I made a similar "find" a year ago, a K75S with 8700 miles on it (vin .....50905) unfortunately mine was the blue/green color.
Have you had a chance to look at the brakes yet? If the fuel system had brown sludge in it you'll probably find the same thing in the brake lines and Mcylinders.
Good luck with your "new" bike. After its initial clean up mine has been a real joy to ride this past summer.
Greg,So...where are the pictures??
Good morning K-bike wizards,
I'm still waiting for my mail-ordered Clymers to arrive. ITMT, I've discovered the fork turns VERY stiffly and is in need of bearing removal, cleaning and repacking. I would like to get this done while the wheels are off waiting for tires. I have the bike on a lift with the front fairing/headlamp/instrument cluster and front wheel off. The calipers are also off the fork legs. It seems that the front brake hydraulic tube that runs through the steering head may need to be removed. If so, how does it come out? If it can stay in, what is the next step in getting to the bearings? What grease is recommended?
As always, thanks for any information.
Dr. Paul
Thanks, Greg. Does the brake fluid pipe pull straight out or unscrew? Mine seems pretty snug in there and doesn't want to budge.You have to open the brake system to remove that pipe from the fork head. I has a "Y" at the bottom so comes out by disconnecting it from the top.
K75's have a rubber steering dampener inside the fork head. It's a rubber collar with a square waffle pattern inside which holds special silicone grease. Once you have pulled the steering stem out (from the bottom) you can remove the dampener by removing the two allen screws at either side of the fork head. BMW says to only use their special silicon grease to fill the "reservoir" spaces on the dampener.
When you put everything back together, you'll need to get the dampener aligned vertically so some of it's metal backing is exposed to the pointed ends of the allen screws. You leave the dampener loose while setting the fork bearing pre-load and only tighten the allen screws (thus "turning on" the dampener) after the preload is set.
BelRay makes an excellent high pressure water proof wheel bearing grease, but just about any good wheel bearing grease will work.
Paul
I will try that. And thanks again!Once it's free at the top it should just pull out. Could be stuck with crud - maybe drizzle some WD40 down the sides?
Drive shaft removed without difficulty. Splines are perfect. The grease on the rear spline was a bit hardened but the front spline lube looked new. Found the Moly 60 at my local Honda shop. Should get relubed and back in today.The only remaining fuel system component that has not been cleaned, replaced or repaired is the fuel pressure regulator. I'm sure it was exposed to the same fuel stagnation problems as the rest of the system. Any way to clean and test prior to reassembling everything? Maybe just replace now??
Still wondering if anyone has information on cleaning or testing the fuel pressure regulator. It's a $100 so would like to salvage if possible. Thanks!
Paul
Chevron Techron Forever!Did I say I worship at the altar of regular use of a good fuel system cleaner?
Thanks for the advice on cleaning and testing the regulator. I will do that this weekend.
Paul
Techron rocks! I always use Chevron gas, and now Texaco has Techron. I also run a tank treated richly with the Techron additive before every oil change. I've done this on all my vehicles (cars & bikes) for many years and I just never have fuel system problems.
