Results 1 to 13 of 13
Thread: new fuel filter now no run
    smilinrider
    Unhappy new fuel filter now no run
    hi everyone...
    i am a new member..first time on this forum
    hope someone can help.
    i just installed a new fuel filter and spark plugs. in my 1985 k100rt...and now all she'll do is idle poorly..if i try to give it any throttle, it dies...same with the choke.
    any help would be appreciated
    thanx
    smilin rider
    Go back where you were.
    Fuel filter - check that the clamps are tight and the hoses not twisted/crimped.
    Spark plugs - check that the wires are on the correct spark plugs. Make sure all wires are firmly seated on the plugs.
    smilinrider
    new fuel filter
    thanx for reply
    i went back in and disconnected outlet side of filter...ran starter....plenty of fuel pressure....checked fuel at injector side..fuel gets there...plug wires are hard to mess up...all seated good...i hear a tick at fuel injectors..sounds like spark plug arcing out.... but no sparks anywhere...could wires to injectors be shorting out?
    Urbana, IL
    Quote Originally Posted by smilinrider View Post
    hi everyone...
    thanx
    smilin rider
    Any chance you pulled the air intake from the air flow meter off the intake box to the throttle bodies? It's not really related to the area you say you worked on, but the symptoms are similar.
    R1200GS LC Rallye
    Maine Rider cayuse60's Avatar
    Mar 2007
    Brunswick, Maine
    Type spark plug and GAP??
    Tim
    1997 K1100 LT
    " If you don't know where you are going, any road will get you there." And that is OK with me
    MichiganMike MICHIGANMIKE's Avatar
    Hudsonville MI
    Jack's Reply
    Jack H. wrote: possible disconnect of the air mass sensor.
    Jack, where exactly are you saying the disconnect might be? In the airbox?
    or down at the throttle body area?
    I have the same symptoms on my K75. Maybe you can help both of us out with a more detailed way to check this out.
    Mike Hankinson Hudsonville MI
    Urbana, IL
    Quote Originally Posted by MichiganMike View Post
    Sometimes if you have a backfire or maybe it is just loose, the big rubber tube from the air flow meter comes off. It goes from the air filter box under the backbone to the throttle body air intake (where it can come off). I suppose it could also get rotted and have a big hole in it too. If you don't draw all your air thru the air filter box (and air flow meter), then the bike will start and idle but die when you try to give it some throttle.
    R1200GS LC Rallye
    IF all the other suggestions do not solve the problem... The BMW Dealer in Grand Rapids, Michigan tells me that they have had many cases where a fuel filter has been replaced and then the bike runs poorly, if at all (K & Oilheads). Turns out that quite often the act of pulling off the filter from old fuel hoses causes a hairline split in one of them, resulting in rough running.
    In my case, on a K12LT, the situation was slightly different. After doing the 50,000 mile maintenance, the bike ran rough, quit, and would no longer start. Turns out I tried one too many times to use those squeeze-type fuel clamps on the filter without the proper tool...I used an ordinary pair of pliers because did not want to fork out the money for an expensive crimping tool only to use it a couple of times. I currently have one whole tool chest drawer full of these specialized tools accumulated over the years. Well, the ineffective crimp allowed the hose to pop off. After the renewed fun to R&R all the tupperware on the KLT in order to remove the tank, I purchased the screw-type SS clamps from the dealer. Tedious!
    Mar 2007
    Brunswick, Maine
    If you find it to be the internal tank fuel lines make sure you replace with fuel submersible fuel line...either BMW replacement or SAE 30R10, 5/16 fuel injection rated fuel line (100 PSI) from Gates or NAPA P/N H209 ($20.00/FT). Otherwise the line will slowly deteriate in the fuel once submerged.
    Tim
    1997 K1100 LT
    Hudsonville MI
    K75 Up & Running
    Jack and all, I went back and rechecked the hose at the front of the airbox and found I had a bad seal at the end of the hose that connects to the throttle body area. The hose seems good but when I resealed it around the opening and put the clamp back on tight the bike fires right up. Thanks again for sending me back to the obvious. Now note to self, never buy a faired bike again. All that plastic is a pain in the butt to put back in place. For the K100 owner, check that hose at the front of the air box for both end clamps to insure it is sealed properly. Hope your bike is up and running soon.
    kayseventyfive
    Quote Originally Posted by cayuse60 View Post
    Be careful what they sell you. It needs to have the SAE rating on it. The kid in the shop at my so-called BMW dealer told me the transmission cooler hose they put in the tank was fine. Gates number for SAE 30R10 5/16 is 27093.
    Lindbeem
    New fuel pump,new filter,87 k100 won't start
    I am hoping someone can can give a clue of what to do . The closest dealer is in Mpls
    Minn. does any one have any suggestions ? Is there any one closer who can get this baby started and running ? I live near Eau Claire Wi. Pat L
    mrich12000
    Arrow Fuel who
    So It won't go..
    go back into the tank take that filter and check it for the flow. then recheck the fuel reg vacum hose , then check the Air valve as stated ,by mike's Good words
    parts tip#12
    Fram G2 filter plastic clear work very well and it cost 1.50us.. The proper hose clamps are included
    Mike Richard
    126360 Loonie-Tic
    K75RT
