Page 3 of 12 FirstFirst 1 2 3 4 5 ... LastLast
Results 31 to 45 of 169
Thread: Final Drive Viscosity?
  1. #31
    The recommended for BMW motorcycles language on the 75w140 bottle applies to transmissions. It even says so in the repair manuals.
    But the repair manuals do not say so for final drives.
    It's your bike - use what you wish. I prefer to use the grade and viscosity specified by BMW as stated in the repair manuals and owner's manuals.
  2. #32
    gulfcoastbeemer
    Have you actually read the the bottle -- that is, Gear Oil BMW 75W140 Super Synthetic?
    This bottle does NOT mention transmission or final drive. It labeled GEAR OIL -- without any further clarification.
    I don't know whose "repair manual" you are citing; but the BMW REP-ROM repair manual clearly states:
    Final Drive: Castrol SAF-XO
    Gear Box: Brand Name hypoid-gear lubricant SAE 90 API GL 5
    As you can see the, BMW Repair Manual (REP-ROM) does NOT recommend BMW Gear Oil 75W140 in either application. So this seems to beg the question: is BMW NA marketing an oil that has no known application, or is there is some BMW service bulletin or BMW publication that clarifies where this GEAR OIL should be used.
    The BMW Rider's Manual (US Model) R1200RT 3rd Edition: Rear-wheel drive design; Shaft drive with bevel gears (no mention of lubricant type).
    Please share with us what BMW publication you are citing, and quote it.
  3. #33
    Yes - I have read the gear oil bottles for all three types of BMW branded gear oil.
    The 75w140 synthetic says it is suitable for all post 1970 BMW motorcycles - without reference to transmissions or final drives.
    The 80w90 says that it is suitable for use in transmissions AND final drives for 1970 and later BMW motorcycles.
    The 75w90 synthetic also specifically references both transmissions AND final drives on post 1970 motorcycles.
    I do happen to think that the language that is used on the 75w140 bottle is misleading. I am sure the differences in the language on the 80w90 and 75w90 bottles making reference specifically to transmissions and final drives was no accident. I also suspect that the vague language on the 75w140 where "motorcycles" were mentioned but final drives were not mentioned was also no accident.
    In any event - the repair manuals and little owner's manuals for each model published by BMW do specify the correct lubricant to use in the transmission and final drive; to wit for the old style Oilhead and K bike drives:
    Transmission: 90 wt GL5 gear oil if over 42 degrees F; 80 wt GL5 gear oil if under 42 degrees F; 80w90 wt GL5 gear oil OR 75W140 GL5 gear oil are acceptable substitutes.
    Final Drive: 90 wt GL5 gear oil if over 42 degrees F; 80 wt GL5 gear oil if under 42 degrees F; 80w90 wt GL5 gear is an acceptable substitute.
    I have previously stated publicly and written in the Owners News (July, 2007) that it is my carefully considered personal opinion that the use of improper viscosity gear oil which is thicker than specification is a contributing factor in the rather sudden increase in final drive failures which occurred time coincident with the introduction of the BMW branded 75w140 gear oil on the dealership shelves, and its widespread out-of-spec use by dealers and owners.
    I have been chided and yelled at by a few dealers for that position but not one has yet been able to provide me documentation or a reference to documentation from BMW that says that anything heavier than 80w90 is acceptable in final drives. A couple of people did write that the "bottle says its OK", but given the specific language about final drives on the 80w90 and 75w90 bottles I don't believe the vague reference to "motorcycles" on the 75w140 bottle trumps the language in repair manuals or owner's manuals.
    As for which documents: for the new sealed drives, the document is the bulletin issued by BMW pertaining to the oil change at the 600 miles service. it says 75w90. The 75w90 oil is also shown on the repair parts listing.
    As for the older style final drives, what I wrote above is what it says in my R1100RS, R1150R, R1100S, K1100LT, and K75 owners manuals and my R1100RS/GS Repair Manual and my R1150RT and R1100S Repair Manual CDs.
    But - as I wrote earlier - its your bike. Use what you want. I prefer to use gear oil which meets the viscosity specifications published by BMW.
  4. #34
    One more thought on the topic.
    Since several dealers have only been able to show me specifications for final drive lubricant of 90 wt, 80 wt, 80w90 wt, or 75w90 wt. gear oil - maybe the owners on this forum can find additional specifications for one or more specific models. I've looked at over a dozen repair manuals but haven't looked at them all.
    So: if you have a little book (Owner's or Rider's Manual) or a Repair Manual published by BMW for a post 1970 BMW motorcycle that specifies a FINAL DRIVE GEAR OIL THICKER THAN 90 WT please post that information here.
    I don't think we need every reference to "yes - it says 90 wt" but certainly if it says anything heavier than 90 wt it would be instructive.
    Please be specific - model, year, which manual, date of manual, etc.
  5. #35
    gulfcoastbeemer
    I just had a telephone conversation with BMW North America Customer Relations in Woodcliff Lake, NJ regarding what gear oil was to be used in my wife's '05 R1200RT and my '07 R1200RT. The BMW NA representative was very attentive to my concern and seemed very knowledgeable on the issue of final drive lubricant.
    He referenced internal discussions that BMW Customer Relations had recently had with technical representatives within BMW regarding this very issue. This was not his first call on this issue. This Customer Relations representative felt he was up to speed on the issue and was familiar with all currently available information regarding final drive lubricant.
    The BMW NA Customer Relations representative clearly stated that either BMW Gear Oil product -- 75W90 or 75W140 Super Synthetic was recommended in my final drive. He did state that ultimately individual BMW dealers might have a preference based on other considerations as to which might be used-- he didn't elaborate, perhaps climate or season of the year, who knows. But, in any event, he was very clear that BMW had formulated 75W140 Super Synthetic for use in the final drive of my particular model/year BMW motorcycles, and under no circumstance was it harmful to the final drive of these vehicles.
    If anyone else want to have a go at it, the telephone number for BMW NA is 1-800-831-1117.
  6. #36
    I'm glad BMW tech reps and service reps now have the Hexhead and New K bike drive lube figured out.
    They originally said there was a lifetime fill from the factory. Then they said change it at 600 miles. When I asked what to fill it with at 600 miles they said 75w140 synthetic. That's what I wrote in my July article. Then they issued the bulletin which said 75w90 and showed 75w90 on the parts fiche.
    Now they say verbally either is acceptable. I'll accept that. I feel better because that means my article in July wasn't wrong.
    Since the bulletin says 75w90 and that's what they show on the fiche, I would personally still use the 75w90 but Customer Service says either is OK, so that's OK by me.
    I still would like to see any BMW documentation (if it exists) as to heavier than 90 wt oil in the Oilhead and old K bike final drives.
    If any body has such in an owner's or repair manual that specs heavier than 90 wt. please let me know.
  7. #37
    Registered User marcopolo's Avatar
    Feb 2005
    Alexandria Virginia/Ottawa, Canada
    FWIW, when my independent BMW Master tech changed the FD oil in my '06 R12RT in November 2006, he used "SAF-XO Synth F/D Oil". I know it was Castrol from looking at the bottle (after he told me the price, I wanted to check it out). He said that that's what BMW specified.
    In July 2007, my final drive failed on a long trip and was replaced (under warranty) in Salt Lake City. A week later, I had the FD oil changed in my new final drive at Brown Motor Works, the BMW dealer in Pomona, California. They used "Super Synth 75/90", P/N 07510394082.
    Mark
    2015 R 1200 GS Adventure
  8. #38
    Registered User soffiler's Avatar
    Nov 2005
    Sterling, CT
    Well, this isn't precisely what Paul is asking, but since this is the Hexhead forum, it seems pertinent to list what the hexhead's Rider's Manual says about the final drive lubricant:
    nothing. zero, zip, zilch, the bubble.
    More specifically, under "Fuels and Lubricants" on pp. 167-168, the only mention of gear oil is with respect to the transmission, and it calls for Castrol SAF-XO. No surprise there. Nor is there any surprise that they ignore the final drive lubricant, since back then everyone was still under the impression that it was a lifetime lubricant from the factory.
    The Haynes Manual "BMW R1200 Twins '04-'06" (copyright Haynes Publishing 2007) likewise ignores the final drive lubricant. For the transmission it calls out "API grade GL-5 SAE 90"
    This is an '05 R1200GS built 12/04; can't find any date on the Rider's Manual.
    Steve O. - MOA #122171
    '05 R12GS, '76 CB200 (wife's)
    '91 K100RS, '87 Honda CBR1000 Hurricane, '84 Yamaha FJ1100, '85 Honda VF500F, '76 Yamaha RD400, '82 Honda XL500... and more
  9. #39
    May 2006
    Havertown/Corte Madera
    2007 owners manual
    R1200ST, 2007, purchased 7/07, owners manual, 3rd edition 6/2006.
    This little book says absolutely nothing about lubricant specs for either the FD or the tranny, it only mentions engine oil. I was surprised at the omission and double checked, nothing.
    Following the most recent BMW bulletin makes as much sense to me as anything else here.
  10. #40
    Urbana, IL
    Quote Originally Posted by progress49 View Post
    This kind of issue is the most frustrating. So far the bulletin is the way to go, but it says nothing about the bikes earlier than '07. One report on this forum said that BMWNA's advice on the phone was to change all the new FD bikes fluid no matter what year with the new synth 75W90. Many dealers probably don't know that, whether it is advisable or not. Is this person at BMWNA knowledgeable? Then dealers also make their own policy to use one FD oil or another and periodic changes or not as their experience or lack of it directs. The underlying cause of all this confusion is a total lack of guidance from BMW on the issue and the cause of that is probably worry about opening themselves up to warranty fluid changes and litigation.
    Except for Death Valley in the summertime, I think I'll stay with the 75W90 synth.
    R1200GS LC Rallye
  11. #41
    Registered User GSWayne's Avatar
    Feb 2006
    Santa Barbara, CA
    The 75W90 synthetic seems hard to find from the the Internet BMW dealers like Max's, Hammersley, A+S, Chicago and Sierra BMW. Anybody know of a source?
    The 75W140 seems more common.
  12. #42
    Quote Originally Posted by SBWayne View Post
    Engle Motors in Kansas City has it. Gina's BMW in Iowa City has it. Any BMW dealer can get it - and per the bulletin ought to be using it. Unless they have a better idea.
  13. #43
    Urbana, IL
    Twin City BMW, in Savoy IL has it. They don't have any 140 at the moment.
    217-356-0399
    BTW they are having an open house next Sat Oct 20.
    R1200GS LC Rallye
  14. #44
    Registered User TomR1200's Avatar
    May 2007
    Northern Virginia
    Everyone seems to be saying "the bulletin" requires 75-90 synth. I was at the dealer today, and he dug out the bulletin that requires changing the FD fluid at 600 miles for '07 bikes, and guess what? It doesn't mention viscosity. I read both pages. Is there a different bulletin everyone is talking about? Could someone post a copy of it?
  15. #45
    May 2007
    Northern Virginia
    Yes. BMW issued a bulletin/instructions for changing the fluid in the 2007 models at 600 miles. Ask your dealer to see that bulletin and then ask the dealer to use the viscosity stated in that bulletin. Don't ask what they "prefer." Ask what BMW told them to use.
    Paul, I just read that bulletin today, and there is no mention of viscosity anywhere on it. Were there two dealing with the same subject?
    Tom
