Results 1 to 5 of 5
Thread: '93 K1100RS: considering buying...any advice?
    On the Road
    Aug 2007
    NYC and San Fran City
    hello,
    i'm looking into a used '93 K1100RS with 22,000 mi.
    i've owned boxer's now and before and only test ridden a k once before so i don't know very much about these beemer.
    any advice as what to look for, maintenace issue's for this model and mileage, etc.
    thanks in advance...
    MysticRed
    Header bolts need to be checked for tightness once in a while, prone to coming loose I hear. Splines need serviced at about 40K or so. How was it maintained? If it was by the book you have no worries. They're pretty bullet proof.
    I don't know what kind of climate you live in but be advised that you are very protected by the fairing and A LOT of heat comes up around and through the tank! It feels good when it's cold but over 90 it can be stifling.
    Registered User Beemer01's Avatar
    Mar 2007
    Chicago, Ill
    Thoughts and a link
    http://www.verrill.com/moto/kbikebuyingguide.shtml
    Tips on buying a BMW including the K series you are considering.
    I have a first generation 1985 K100RS. The heat off a RS is not as bad as the more fully faired LT. There are countless threads on how to reduce the heat.
    Mudbug
    The tank is aluminum and gets hot in the summer sun just like the hood of a parked car. I have a K100RS, predecessor to the K1100RS, and I have never noticed excessive heat that so many talk about. The bike is rock solid and almost bullet proof.
    The K1100RS is a great bike. If I were in the market for another BMW K bike, the K1100RS would be my first choice.
    Feb 2007
    Santa Barbara CA, about 90 mi North of LA.
    Cool Go for it!!
    Hydranyc, Go for it! That is low miles for the bike. I have a '93, bought 2 years ago with 36K. It's been great! I will echo the heat issue, especially here W. coast, but I am smiling too much to give that a negative. I will also tell you that the speedo problems you hear about can be a real pain, mine has died, but with help from this board I was able to get it working again. Most shops are not working them now. My issue was a loose trigger ring in the final drive. Zoom Zoom, HOWL... is not just Mazda! KC
