Page 61 of 61 FirstFirst ... 11 51 59 60 61
Results 901 to 909 of 909
Thread: How do I post a picture?
  1. #901
    Nov 2005
    Calgary, Alberta
    Test [Smug Mug blues, again]
    Rinty
  2. #902
    Registered User Subman's Avatar
    Jul 2014
    Maine
    Test
    Test
    Dave K.
    1971 R75/5
  3. #903
    Test
    Test
  4. #904
    Jul 2018
    Hilliard, OH
    Test
  5. #905
    test pic
    Test pic
  6. #906
    Aug 2005
    Deerfield, Ohio
    My 1980 R100T. Don't let the starter cover, air box, and valve covers fool you. I like the retro look. But surprise! When I went to peel off the BMW engine name plate from my original modern starter cover I found that is was cast as part of the cover. Once I source the proper name plate I will replace the R75/6 still on the starter cover. Search in progress.
  7. #907
    Mansfield,MA
    Quote Originally Posted by daz View Post
    You got it!......
    Along with a mobile work station concept
    Mod Squad
    2009 F800GS 1994 TW200
  8. #908
    Liaison 20774's Avatar
    I don't remember that the engine badges were cast into the cover...they should be held on with factory glue unless someone has changed things on your bike:
    https://www.realoem.com/bmw/enUS/sho...34#51141257535
    Plus, how does an '80 R100T have a badge for a R75/5 or /6??
  9. #909
    Aug 2005
    Deerfield, Ohio
    I guess I wasn't clear enough. My 1980 R100T had the new style starter cover, etc. I wanted the older style. I switched those parts from a /6. The newer cover had the badges cast on it. So I CAN remove the /6 badge but I have no newer badge to take its place on my retro starter cover. They are available from older R100s but I have not sourced a set yet.
    Just to make my bike look a little retro. I like the look better.
