Page 32 of 60 FirstFirst ... 22 30 31 32 33 34 42 ... LastLast
Results 466 to 480 of 893
Thread: How do I post a picture?
  1. #466
    Registered User lewlei's Avatar
    Feb 2004
    Melbourne, FL
    Ok, let's see if it works ...
    I think I've got it (well maybe)
    Lew, on the road to . . . ??
  2. #467
    Feb 2004
    Melbourne, FL
    It really works!
    Rocket Man, thanks for the help. Easy when you know what you're looking for. Trouble is on my display of icons, the paper clip looks more like an exclamation point (to these weak eyes, it is very small). I have an older version of photoshop (5.0) and sized the image down to 300/xxx. Looks like for good scenics, I can double that and it should be just right.
    Lew
  3. #468
    Jul 2008
    Mesa, AZ
    Some day I might get it
    I think I found the Paper clip.
  4. #469
    rocketman
    Quote Originally Posted by baja65 View Post
    yes it should be in box on the left side of your desk, next to the pencil cup..
    no..
    not that left, your other left...
    yes, now back a bit,
    yup, there right under your calendar and next to your inbox.....
    good, now can you please turn off your internet cam its playing hell with my bandwidth.....
    RM
  5. #470
    Registered User soffiler's Avatar
    Nov 2005
    Sterling, CT
    Testing: can I post more than one pic in a message?
    testing
    ...Ah-ha... "you have uploaded the maximum of 1 files"
    Steve O. - MOA #122171
    '05 R12GS, '76 CB200 (wife's)
    '91 K100RS, '87 Honda CBR1000 Hurricane, '84 Yamaha FJ1100, '85 Honda VF500F, '76 Yamaha RD400, '82 Honda XL500... and more
  6. #471
    Nov 2005
    Sterling, CT
    can I use links to post pics?
    testing - YES!
  7. #472
    isavem1
    just checking
    want to see if my photo shows up under my name.
  8. #473
    Intermediate Adventurer Newstar's Avatar
    Landenberg, PA
    testing
  9. #474
    Nov 2005
    Calgary, Alberta
    pictures
    Get that Norge up there, Tracy.
    Rinty
  10. #475
    rocketman
    Quote Originally Posted by Vagabird View Post
    use the "[img]" tags not the [url]
    as here
    you can right-click on the image on your site to get the properties dialog box and cut and paste
    also note it must end in a ".jpg" extension (or other graphic extension)
    most sites have a way to generate the proper tags so you can then just cut and paste from that into the post on the forum.
    RM
  11. #476
    Jul 2008
    Portland OR
    And again
    embed photo?
    '16 R1200RS
    You only live once, but if you do it right, once is enough. -- Mae West
  12. #477
    rocketman
    embed photo?
    thats one way, again the other is to right click on the image on your site, then go to the bottom of the pup-up and click on the "Properties" option at the bottom, this will bring up a "properties" pop-up, then copy the info on the line marked "address", paste that here and put the [img] tags around the text. if you quote any post with a picture you can see the formatting of the [img] tags.
    RM
  13. #478
    Velocity Joint moezilla's Avatar
    Dec 2005
    SW MO Ozarks
    just seeing if this works
    Testing, 1,2,3 etc
    "You must be fast, 'cause I was hauling *** when I passed you!"
  14. #479
    Dec 2005
    SW MO Ozarks
    one more time
  15. #480
    Wisconsin and Florida
    Why would one want to download software that does essentially the same things
    you can do with Windows Paint which is part of XP&Vista Accessories inc in Op sys?
    Or KlourPaint which is inc in many Linux systems?
