Picture of an oil sight glass it appears? I don't think I'm signed into a google account...although I can go to my gmail account without having to enter my credentials. Does that count?
probably signed in then - although having someone other than me see it is a step in the right direction. now for a non-google user...
This is the process I followed (stolen from an ADVrider post):
Here's the scoop on posting images from Google Photos...
___
First, the images need to be in an album that has been shared with the "Get Link" option. You will not use the generated link to embed photos as that is just a link to the album gallery, but if you do not do this share action then you end up with the situation where you can see your posted photos but no one else can. I have an album called "web" where I keep all my random publicly posted images.
___
While viewing the album, click on the picture that you want to embed in a forum post so that you are now viewing the single image. You have to be viewing the single image. If you try to copy the image URL from the album gallery it will not work. I'm going to use that first pic of the ass end of my 990 Adventure.
___
Right-click on the image and select "Copy Image Address" or whatever gets you the URL of the image. This is NOT the same as the URL in the address bar of your browser, so do not copy it from there.
___
This will yield a very long link with some important information at the end. It looks like this....
Code:
https://lh3.googleusercontent.com/A6...g=w603-h804-no
___
See the "=w603-h804" at the end of the URL? That represents the rendered size of the image (603px X 804px) and is going to be important in a minute. Note that the exact width specified in the copied URL is not the original size of the photo, but is directly a result of the size of your browser window when you copied the image address.
So now click the image button in the post editor and paste the URL into the dialog box...
___
Now what you do is edit the end of the URL so that the width is something appropriate for posting in a forum. I find that 800px or 1024px width works great. As you can see from the info in the "single image" view above the original is 1536px wide, so we will set it to 800px wide and remove the rest so the height can sort itself out proportionally.
___
Now hit insert and the result will be the image sized to 800px wide.
___
Finally, you can verify that all is well by viewing your post in an "Incognito" browser window - aka porn mode. This will reveal if the album and its pictures are properly shared so others will see them.
___
Hope that helps folks. Once you get used to the process you get to where you can fairly quickly flip through a gallery and get all the photos inserted. yeah it's a bit of a pain with the forced "upgrade" from Picasa Web, but it's doable.
1995 (+ some 1996) R1100RS / RSL
My bike: https://picasaweb.google.com/rxcrider/1995R1100RSRSL
My parts: https://picasaweb.google.com/rxcrider/1996R1100RSL
Signed out of my google gmail account...can still see the picture.
Yeah, there seems to be something in the translation for pictures taken with an iPhone. A "workaround" is described on the preceding pages and is basically, the way I understand it, is to ever so slightly ad some rotation to the iPhone"s picture.
I haven't figured out anything better.
Gary
Mod Squad
2009 F800GS 1994 TW200
^^^^^Looking Good!^^^^^
om
Mod Squad
I want to attach a .pdf file in its original size of 258 KB. But it fails because the file size is above the 153 KB limit.
I don't want the content of the file to show in the post - just make it downloadable.
Any way to do this?
Thanks!
Guenther
Guenther -
I just uploaded a 522Kb PDF file so your size is not the limitation. If I understand the attachment screen, it seems to indicate that the max limit is 6Mb. I don't think I have any more privileges than you regarding attachments, so there must be another issue. I could try and upload the file if you want to email it to me. I'll PM you my email address.
Guenther -
Here's the PDF file I uploaded. Schaltplan R100GS-2.pdf Things went OK for me.
Test
jZ
There is some perverse beauty about being up in the air looking down at your bike during a high-side get-off.
My K1200RS
test
