Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 35
Thread: R1200RT alternator belt replacement
    CENTEX USA
    cannot find link to alternator belt replacement on the R1200, have the DVD but not on my copy....got old one off using plastic sleeve, need help rolling new one on! fingers are not a good idea . I saw the tips on the GS site, but he had issues also
    Definitely easier on the oilheads!, I would hate to lose one on the road, cause you aren't going to pop it on like you can the 1100' or 1150's. The RT requires the tank to come off to really get your hands in there, luckily I was flushing the ABS & changing spark plugs anyways and have all the tupperware off as well as the tank
    Steve Henson-Mod Team and club tire changer
    Urbana, IL
    BMW has a neat tool for this. Kind of an inclined spiral that neatly spins the belt right on. I forget the cost to the dealer...some hundreds of dollars...mandatory.
    My other bike is a BMW.
    CENTEX USA
    Quote Originally Posted by cjack View Post
    no doubt a mandatory aggravation saver... I will be the local specialty tool/tirechanger/bikelift owner before I am done for our club and area... I believe I saw one for under $200 some time back...thanks...I'll go work on another item until trip to dealer tomorrow... needed stuff for another bike anyways and the shop is about a mile from my office...lucky me and y'all wonder why I have multiple bikes???
    Registered User easy's Avatar
    Feb 2005
    Texas Hill Country
    Did the old belt break?
    Easy
    CENTEX USA
    No, just hit 41K and decided it was time...was doing a major maintenance session. The old belt actually looked OK, some minimal cracking in the grooves,I have seen worst serpentines on my cages after 30K.
    CENTEX USA
    FYI...the tool looks like a oil filter tool with a wedge on it...and costs just under $200...all the techs swear by it....
    I need a seperate toolbox for all the "specialty" tools I have bought for various wheeled vehicles the past 35 years...GEEZ, from VW's to Chryslers I have a few!
    If I buy it, It's for rent in Central TX all my Hexhead brothern!You'll need it at 30K
    The GS looks like you can get in there to work without it , the RT not so much...the labor hours on the RT may justify my "emergency purchase" buying justification
    Canon City Colorado
    Two guys needed without tool
    With two guys you can get it on. One person pushes it on while the other (with the bike on the center stand off the rear wheel) put it a high gear and turn the rear wheel. Believe me it works but it is not that much fun, trial and error and which gear is best. . . Hands, brains and muscle can compensate for $$$ tools.
    gpodzo
    Canon City Colorado
    Oops
    I meant the rear wheel is just off the ground not off the bike. You need to spin the wheel while the front person keeps pushing it on.
    CENTEX USA
    Had Helen helping and she's no wimp! (cover my tail disclaimer there!)... Mongo was not around. Felt like we were going to knock bike off of lift! Not the safest method, but I know it's possible without losing a finger or pushing bike off lift!
    Jim VonB said the same thing as you described and the Alt Belt is in same chapter as the air filter replacement on my copy...I will try it again this evening. Jim also thought maybe the front shock will be in way of tool and may have to be removed
    At least the serpentine style belt should last once installed... for a while!
    Use a tie down around the centerstand and the A arm or the forks to prevent the stand from flipping up.
    http://darryl.crafty-fox.com
    CENTEX USA
    OK...I decided to quit forcing things to fit...sure has been some expensive lessons thru the years ( another thread subject!)
    I agree with podsobinski about hands,muscles,brains compensating, but that voice in my head said not this time. I had pinched the doowallee out of my fingers recently...
    Helen was at the dealer helping some new riders gear up about the time I got a call that the hexhead alternator belt tool was in...I'll skip filling my 3/4 ton truck up 3 times and talked myself into going ahead w/ purchase. Asked her to pick it up...She called and said it sure looks like an oil filterwrench, and the British gal with her replied at the cost...must be German! I'll talk British prices with her later
    So after she brought it home and I put it in place, the belt slipped on without a hitch...no manhandling ( or manwomanhandling since Helen is my help). She was installing her new Rick M seat on her R and turned around as I finished to see if I needed some help...DONE ...she couldn't believe after the monkey fugglin we did the other night that it took maybe two minutes. Yes, it was a few more $$ than I wanted, but I bet I have some more new buddies wanting to use it soon! I did not have to remove front shock as had been pondered, I used a small swivelheaded extension and it fit fine, even with Wunderlich engine guard crossbar still in place
    Ain't it pretty? the engineer that designed the snug fit must have had to also build a tool!
    Canon City Colorado
    henzilla let me know
    Henzilla, make sure you come through Colorado with that fancy tool when it is time for my alternator to be changed and bring it with you. . . I'll will take you on some once in a lifetime rides for using that tool.
    gpodzo
    The best modifications cannot be seen from the outside.
    CENTEX USA
    What a deal! I am close to having more riding time anyways
    It will be in my McGyver Bag...people are amazed what I can carry and have in such a small bag! one of my buddies keeps asking when the NoMar is coming to my garage also...I AM spending my kids inheritance...they can have a bike!
    Canon City Colorado
    Better hurry up
    Will look forward to it. I too am spending my kids inheritance on bikes. By the way I am thinking about the Cajan Rally in La. this Nov. My wife has relatives all over SE Texas and western La.
    Don't hesitate coming to Colorado. The aspen leaves will be turning and it is spectacular then, add to that a dusting of snow on top of the mountains and it is a slice of heaven.
    gpodzo
    R1200RT
    R1150GS
    XR650L
    Never try to race an old geezer, he may have one more gear than you.
    Kool Aid Dispenser! jimvonbaden's Avatar
    Mar 2004
    Alexandria, VA
    It IS on my DVD, just after air filter replacement. Somehow the chaper marker got eliminated, and they messed up the label.
    Here is a quick version:
    Add a piece of plastic between the pully and the belt by removing the spark plugs, put the bike in 6th gear, and bump the motor over with the tire until the plastic is in place, then remove the belt with a screwdriver.
    To install it, place the belt as in the next picture, hold tightly with your palm against the belt, and bump the motor over by turning the rear wheel in the driving direction as quickly as you can.
    There you go, I just saved you $200 for a tool!
    Jim
