Beginning April 1st, and running through April 30th, there is a new 2024 BMW MOA Election discussion area within The Club section of the forum. Within this forum area is also a sticky post that provides the ground rules for participating in the Election forum area. Also, the candidates statements are provided. Please read before joining the conversation, because the rules are very specific to maintain civility.
You can mount the horn exactly where the original mounts. Great location.
As for wiring you can use the existing horn wire to trigger the relay.
You must power the horn from the battery directly or through a Centech or Blue Sea fuse panel. I believe that thing sucks about 30 amps.
If you don't have a relay just pick one up from local auto parts source. They usually come with a wiring diagram as well.You will also need an inline fuse holder or use a fuse panel. It's actually quite simple, just make proper connections and try to tape all the connectors on the relay to protect them from the elements
I'll see if I still have the instruction sheet and if so will email you copy.
John
