R
RTNewbie
This morning on my commute, while coming to a nice controlled stop at a light, my rear brake pedal slowly traveled to the end of its stroke. The rear braking simultaneously faded to nothing in the process.
Assuming a leak in a brake line or something I discontinued use of the rear brake to avoid squirting fluid on my rear tire or anything else.
On arrival at work I cycled the brake lever several times expecting to see fluid weeping out somewhere. None to be found. I did notice a slight squirting sound coming from the master cylinder/reservior area when the pedal was cycled which turned out to be fluid squirting back into the reservior.
I think this must be a failed master cylinder piston seal but i cannot find any threads to confirm. Has anyone dealt with this problem on an oil head? For reference, mine is a '96 R1100RT.
Gotta get this fixed before the National!
Thanks in advance.
Thanks in advance.
