Results 1 to 5 of 5
Thread: Trouble Shooting Help Please!
    Registered User LCampbell's Avatar
    Nov 2006
    Vacaville Ca.
    I have a 99 R1100RT with 58000 miles on it. The problem I'm having comes & goes. As I am riding along the bike will be running smoothly & then start to run rough (rough might not be the right word "Buzzy describes it better)that is the vibration thru the bars increases & the mirrors get blurry. If I feel the valve cover when it's doing this the left side seems to be vibrating more than the right side.
    I have replaced the plugs, checked the valve adjustment & resynched the throttle bodies & it still does it.
    The left plug wire resistance using a digital multimeter is 5.80 K ohms. The right plug wire is 6.01 K ohms (The info on the plug wires says they should be 1.0 K ohms)
    On the coil I get 0.6 ohms across the green / black connectors & 07.16 K ohms across the high tension leads. Am I checking this properly?
    To me it looks like I need 2 new plug wires & a coil (My Haynes manual indicates that the secondary winding resistance should be 13 K ohms) Are the secondary windings the same as the high tension leads?
    Is there anything else I should check? Any suggestions would be greatly appreciated.
    Quote Originally Posted by LCampbell View Post
    Your coil is good. The Haynes is wrong.
    Nov 2006
    Vacaville Ca.
    Thanks for the update. I talked to a very helpful guy yesterday at the Beemer Boneyard after I made the first post & he told me the same think. He said that I should check out the throttlebodies & also do my off idle sync at a higher rpm
    Boulder, CO
    If you have a TwinMax you can tape it to your gas cap and hook it up. Then go for a ride and watch the balance when the vibration occurrs. Bring along a 10mm box wrench and adjust the right side cable adjuster until you get the balance equal at the RPMs that is causing you trouble. It may take 2 or 3 tries to get it right.
    Nov 2006
    Vacaville Ca.
    I'll try & borrow a Twinmax & try the way you suggest. Thanks.
