Crash bars/cylinder & case protection for R1200Rt
The RT-P does have an oil cooler fan. I've seen them at the dealer here. I know someone on the XPLOR site had the fan added to his RT. He said it was not cheap. Someone else wired in a computer type box fan. It will eventually fail due to rain water but the fans are cheap. That's what I've heard reading on that site.
Robo
for now, I have the plastic ones. Better than nothing, I say.
Here is the overall look with my Cheap-O JC Whitney trunk:
Do those mount w/tape or can you remove them? Those are the ones I have seen painted before, I would leave them like they came since they do catch the ding causing rocks
BTW, like the Red/Granite Grey of your bike:thumb the trunk looks like a GIVI model
the bag protectors are mounted with stickey foam tape. The head protectors bolt on but you have to remove a lot of tupperware.
Re: height challenge
Glenn;
I have a short inseam and coming from a 68 Triumph to
an 06 R12RT I understand. After talking to the DPS guys
here in Arizona I got a couple of tips.
1-If your are going to make a u-turn, you slow down prior
to the turn or as they say you will be one footin it and down
you go. The DPS guy has dumped his twice and he is 5'8".
2- When you stop put only your left foot down. It's a little
different if your used to having both feet flat on the ground.
I found it helped when I got some new boots that raised
my height about 3/4". Practice making u-turns inside of 18" about the spacing of two parking spaces in a parking lot.
Good luck,
Bill
