Results 1 to 5 of 5
Thread: heat guard under hard bag
    MOA 27106 DONPRICE's Avatar
    Aug 2005
    Long Island, New York
    Hey all, I need advice. The metalloid / plastic heat guard under the left side bag that protects from the heat of the muffler has peeled halfway off.
    What adhesive material should I use to glue it back on?
    -Don
    CRUISIN
    I don't (personally) know of many adhesives that hold up to the heat of an exhaust, but cold rivets might do the trick. You could get the longer ones and run all the way through the bag & shield then use a small piece of sheet metal (1/2" x 3") as a backing for the rivets on each end of the shield. That way it should never be a problem again.
    Blocking the slow lane
    Edwardsville, IL
    You could just get a new one? They are cheap.
    Jon Diaz
    BMW K75/K12GT
    BMWMOA Ambassador
    You could use Rutland RTV 500, you could pick it up at any place that sells or service wood/pellet stoves.
    It will withstand temps up to 550 degrees...
    Aug 2005
    Thanks for the responses.
    -The heat shield is not made of a material that would lend itself to riveting, nor would I want to make holes in the bottom of the saddlebag.
    -Buying a new one is always an option
    -I just found some black silicon adhesive in my garage and used it.
    -If that doesn't do the trick, I'll either try the Rutland RTV 500 or get a new part
    Again, thanks for the ideas
