Page 1 of 4 1 2 3 ... LastLast
Results 1 to 15 of 53
Thread: More HP for a K75 (& K100)
    Rally Rat paulsibek's Avatar
    Apr 2004
    near Los Angeles
    Cheap HP for the K75
    Greg Hutchinson, president of the BMW Club of Northern California turned me on to a means of getting more HP and torque recently. I installed this upgrade this weekend and was rewarded with an obvious increase in HP and noticeable performance boost.
    Apparently a number of years ago a couple of engineers, I believe he said from Bosch and TRW found that a set of Ford fuel injectors with a different spray pattern from the stock BMW gave an increase in HP and torque. Greg told me this was proven in dyno tests and I have to agree with the results. My own ‘«£seat of the pants‘«ō experience is that there is a noticeable increase in performance especially at and above 4k rpm.
    This was a very easy upgrade the hardest part was parting with the $160 for the injectors. The installation was easier than I thought it would be with the hardest part being stopping the gas flow from the fuel line to the fuel injector rail. I used a small clamp and the whole process took less than 15 minutes and I am not that mechanical. I got them at NAPA Auto Parts $54 each (Ford has them for $94...)
    Note that I also was told that there is an increase in gas mileage but I didn‘«÷t see this on a 163 mile trip as I think it was because I was a little aggressive on the throttle.
    I don‘«÷t have the part number on me at the moment but I will reply to emails and post it later or tomorrow.
    Maine Rider cayuse60's Avatar
    Mar 2007
    Brunswick, Maine
    Question
    Paul,
    FORD:
    '92-'94 4.9 6 Cyl F1ZZ9F593 B
    Is this the part number?
    Tim
    1997 K1100 LT
    " If you don't know where you are going, any road will get you there." And that is OK with me
    Apr 2004
    near Los Angeles
    Yes
    I believe it is, I will have to double check but it looks correct.
    Blocking the slow lane
    Edwardsville, IL
    Have you ever had your old injectors ultrasonically cleaned? They don't flow too badly once 10 years of varnish is removed.
    Jon Diaz
    BMW K75/K12GT
    BMWMOA Ambassador
    Mar 2007
    Brunswick, Maine
    Tim
    1997 K1100 LT
    May 2007
    Keller,Texas
    Quote Originally Posted by paulsibek View Post
    After a few more tank of gas please let me know if this helps your fuel mileage. If it does do all that then I will make that upgrade. Thanks
    Apr 2004
    near Los Angeles
    Gas Mileage
    I didn't do this for an increase in mileage although it would be nice if there is. I was told by Greg there is.
    I am willing to trade of a mile or two a gallon for the performance.
    If I see an increase I will post it.
    Registered User breyfogle's Avatar
    Aug 2004
    Lomita (aka L.A.), SoCal
    I'd sure like to see side-by-side dyno results. I suspect that any noticable increase is more likely due to comparing new injectors the with old OEM units. Cleaning the OEM injectors would probably produce almost the same performance improvement.
    '89 K75S Original Owner
    '94 (Beta) R11RS, ( RIP 12-5-2010 courtesy of blind left turning cage driver ) ....
    Spring Lake NJ, USA
    I think it's important - that dyno tests be done double-blind (the tester doesn't know what injectors are in the bike for each run).. and they be done back to back, same day, same bike, same weather, same fuel, etc. Also as others noted - new to new injectors if you want real data.
    I find it hard to imagine the mechanism that a differing spray pattern can give more HP by since the intake valves are closed when the injectors spray.. and the vapor/mist sits there until the valve opens and it's sucked into the cylinder. But hey - if the dyno results - done as above - prove it works, it will be the only thing I've heard of besides a turbo that actually gives more HP from a K bike engine.
    Registered User beemerguru's Avatar
    Foster City, CA
    We've been down this path before.. When I first did this swap after the Flagstaff National, I had the 3 different dyno printouts that showed the different, progressively, improved curves. I had maybe 15K on my original 1987 K75 when I went from stock, to CC Products imjector upgrades (BMW 318i units) to these Ford units. I don't think I had enough miles on the engine for so that dirty injectors factored into my results. That paperwork was long gone when it was brought up here again a few years ago. Same arguments.. but no proof. If you can find an old CC Products catalogue, Chris has a printed dyno comparison as part of the parts discription.
    So this time,, who has access to a dyno and a stock, low milage early model K bike?
    Greg Hutchinson
    R80G/S (4) 633CSi with 450K mile
    '68 R60/2 '88 K100RS Special Edition
    http://gregsgssite.shutterfly.com/
    kayseventyfive
    Quote Originally Posted by beemerguru View Post
    No dyno, but I've got a stock K75/2 with about 10K on it. It's so stock it still has those horrible wheelbarrow handlebars.
    Rally Rat bprigge's Avatar
    Nov 2004
    North Branch Minnesota
    Injector Flow Rating?
    Does anybody know what the Ford injector flow rating is and how it compares to the stock BMW injectors? I'm a small block Ford enthusiast and know that there is often more power available by increasing the injector size (flow rating) and also sometimes by decreasing the injector size, all of it depending upon other engine mods. Bruce
    Foster City, CA
    Quote Originally Posted by Kayseventyfive View Post
    Bound to be a place in LALA land with a bike dyno..see what they charge for 2 runs for this experiment.
    Greg Hutchinson
    Spring Lake NJ, USA
    If anyone in the NY metro area has a K75 and the urge (and $$ for the injectors) - I do have access to a dyno..
    Registered User rmarkr's Avatar
    Mar 2007
    Lowcountry
    Injectors
    Fitted the Napa Ford injectors to my 30k mile K100RS.
    It seems to have corrected, what I felt, was a lean running motor (by design, I'm sure).
    Throttle response is 100% better, blip the throttle and the response is instant.
    The boost from 5,000 rpm feels like a supercharger kicking in.
    When warming up it smells rich, havent ridden enough yet to see if economy/range has been hurt.
    Also, I've done a little arthroscopic surgery to the stock exhaust system to relieve back pressure which I feel helps at the higher rpm range. Makes the exhaust note, under load, a little raspy.
    Mark
    "Of all the things I've lost, I miss my mind the most" Mark Twain
