26667
the Wizard of Oz
we did a lot, including removing, cleaning, re-greasing, and replacing steering head bearings. Would you expect the wobble particularly as I decellerate thru about 45mph @ about 4k is most likely caused by improper adjustment of that big top nut? Not as strong a wobble as I accellerate or try to maintain a speed in the mid-forties, and nowhere else up thru indicated 90 mph. Not affected much by changing the setting on the new damper. It's not a tank slapper, but both disconcerting and annoying. Could it be something else, like valves or carb synch? Lower fork brace?
