Results 1 to 10 of 10
Thread: 1987 K75S Issue
    arebin
    I haven't gotten all the parts yet, but I have another small question.
    The mesh screen filter that attaches to the bottom of the pump has an inlet port on the top of it. There was only a broken off piece of fuel line on the fitting. What might this be? Perhaps a hose to run over the hump in to make sure as much fuel as possible is picked up?
    3 Red Bricks
    Jan 2007
    Pleasanton, Ca.
    That hose connects to an aluminum tube at the top of the tank, just to the rear of the filler opening. No clamps required.
    LONG MAY YOUR BRICK FLY!
    Lee Fulton Forum Moderator
    3 Marakesh Red K75Ss
    Mine, Hers, Spare
    67-year-old Teenager indygt's Avatar
    NE Arkansas - Between Goobertown and Buck Snort
    Sounds like corroded injectors
    Sounds suspiciously like what happened when I let my wife's '94 K75S sit for 10 months with a partial tank of gas and no fuel stabilizer.
    I ended up paying about $700 for rebuilt fuel injectors to replace those that were corroded by my neglect.
    I hope you can dodge that particular bullet.
    Good luck.
    arebin
    Wrrrrrrrr. She runs! And pretty well too.
    I'll be getting a set of rebuilt injectors on Tuesday. I figured that they were likely a bit suspect too.
    But, I am having a problem with the tank to chassis electrical connector (4 wires/pins). Seemed to be badly corroded. I've cleaned it as well as I can with WD-40 and dielectric grease, but it still only gets the power to the pump if you pull the wires to the side of the connector.
    Is there a way to pull the female pins w/wire from that connector? I've tried softly, but don't want to mess it up. But it certainly acts as though one of the soldered wires might be about to give it up.
    Any other solutions for a problem connector you guys have used? OEM connectors out there anywhere?
    Registered User breyfogle's Avatar
    Aug 2004
    Lomita (aka L.A.), SoCal
    Quote Originally Posted by arebin View Post
    I had the same problem with the 4-pin connector, suspect most K-bikes have or will have the same problem. In my case the dealer let me cut out the female side of the connector from one of the salvage wiring harnesses he kept just for this purpose. No charge either !
    '89 K75S Original Owner
    '94 (Beta) R11RS, ( RIP 12-5-2010 courtesy of blind left turning cage driver ) ....
    arebin
    Thanks. Beemer Boneyard had a partial main harness that will solve the female connector issue, and that seems to be where the trouble is. And I'll have a decent harness for spares in the future. In the meantime I've kludged up a solution for the short term that involved no wire cutting.
    Took the bike for a longer ride (100 miles) this morning and she is fine. Fine. Very Fine!
    On the Road
    May 2007
    SoCal Valley
    i am going to install and aftermarket pump that may not have a connector on the pump for this hose
    anybody have a suggestion what i should do in this case?
    3 Red Bricks
    Jan 2007
    Pleasanton, Ca.
    Quote Originally Posted by x2nobody View Post
    It is not necessary to connect anything to that. When they changed to the smaller diameter pump that has the sock type pump filter instead of the cup style, they eliminated that hose.
    The early K100 pumps with the cup filter did not have the hose either.
    I am guessing that they had problems with the cup style filter screens trapping air under the pump inlet when the screens got a little dirty so they put that vent hose on to let trapped air out. (any better theories, or actual knowledge??)
    Mine, Hers, Spare
    3 Red Bricks
    Jan 2007
    Pleasanton, Ca.
    [QUOTE=arebin;210379]Wrrrrrrrr. She runs! And pretty well too.
    Another BRICK on the road!!!!
    Mine, Hers, Spare
    On the Road
    May 2007
    SoCal Valley
    from what i have seen in other threads you are probably correct
    and thanks...now i dont have to go find that hose..now i have to wait...and wait to get my pump shipped from a guy on ebay...agonizing to say the least
