A while back, I replacing the front master reservoir on my wife's K75S. While the system was open, I also put speed bleeders on the front calipers.
Because the system had been opened in three places, I expected it to take a while to bleed. But not a half an hour! I kept going back and forth between the front calipers. I wasn't getting much air, but I was getting NO "pedal". I tried the conventional "up down" method on the brake lever and I also tried my vacuum bleeder. Still not much air but NO "pedal".
It seemed like the master was not bleeding properly, like when you don't "prebleed " a master on a car. But I am not aware of a procedure to "prebleed" the bike master.
Besides, I hadn't had this problem when I rebuilt the master cylinder last September. Everything bled fine with no problem.
Up to this point, I had had the bike on the centerstand with the front wheel pointed straight ahead to facilitate going back and forth between the two front calipers.
For some reason, I turned the front wheel all the way one way (sorry, I don't remember which way, but you only have two choices). I got a "pedal" in two pulls!!!
Obviously the angle of the master, when the wheel is pointing straight, was trapping an air bubble in the master.
So, If you ever have a problem when bleeding the front brakes, try turning the front wheel all the way to one side (or the other).
EDIT: Turn bars all the way to the LEFT to get the air out of the master.
