Requesting a little tech Guru Assistance.
On the K11OG forum is a thread about testing the motronic codes by grounding pin 1 on diagnistic connecter and reading the codes on the temp light. After some fiddleing around I finally got it to work. The problem is I keep getting an 1133 code, which says there is a problem with the Hall Effect sensors. The bike is running just fine. It is also noted that the 1133 code can be ambiguous(sp?)
I tried turning the engine over, and even running it, but I can't clear that code. The thread says that this method will only show one code at a time, and that you clear each in turn until you get a 4444 code, that means everything is fine.
So my question is does it show the most severe code first? And can I assume everything else is fine?
It's not that I am any problems with the bike, I just wanted to check everything.
thanks
Rod
thanks
Rod
