chopper_guy
MY "79" R100RT HAS BENT CENTRE STAND LUGS WITH DEFORMED BOLT THREADS. I AM PLANNING ON STRIPPING EVERYTHING OFF AND GETTING SOME WELDING DONE TO REPAIR IT. AT THE SAME TME I WANT TO REPAINT ALL OF THE BLACK FRAME PARTS SHINY BLACK, AND SOME ENGINE COVERS,(FRONT,TIMING,ROCKER, EXTENDED SUMP,AIR BOX,STARTER), AND EXHAUST PIPES, FLAT BLACK. CAN A GOOD JOB BE DONE USING SPRAY PAINT? WHAT PREP SHOULD BE DONE? IS A PROFESSIONAL JOB THE ONLY WAY TO GET A DURABLE FINISH? I HAVE ALWAYS THOUGHT THAT FLAT BLACK WAS THE BEST RADIATOR OF HEAT. IS THIS TRUE?HOPE SOMEONE WILL HAVE SOME SUGGESTIONS. THANKS IN ADVANCE.
