Results 1 to 14 of 14
Thread: Fuel light stays on ???
    jackyd
    I just purchased a 1995 R1100R with 18k miles. After driving for about 200 miles fuel light began to come on when tank was about 1/2 full. Now light stays on continually, even after fill up.
    Any suggestions to how to fix?
    Jack
    How cold was it? shoeman's Avatar
    Jun 2004
    Lake Wabaunsee, Kansas
    maty be a sticky float or prox switch. try some Chevron Techron in the tank and swirl, or remove float sender and clean and inspect.
    Jim Johnson, OP Kansas
    Marcus Aurelius: "The object of life is not to be on the side of the majority, but to escape finding oneself in the ranks of the insane."
    sportridertex
    Had a Similar problem
    I had a similar problem on my R1100RT, after a service which included the fuel filter change out. The independent shop I was using, had to go back into the tank. They found that the Low Level Amber light float sensor was hanging up on one of the hose clamps in the tank.
    jackyd
    Low Fuel Light Stays On
    Phil
    I hope it is that simple
    JACK
    BUBBAZANETTI
    Quote Originally Posted by jackyd
    Jack
    200 miles without filling up??? that would be much more than half a tank on that particular model, 5.5 gallons, considering the average mpg of a 1100 series oilhead to be 40-45mpg would mean your gas light should be coming on right around 180 miles or so.
    USERNAME
    Quote Originally Posted by BubbaZanetti
    i read his post as... "for the first 200 miles i rode the bike, everything was fine. then i started having problems with the fuel light. it came on when i still had half a tank fo fuel. now it stays on all the time."
    BUBBAZANETTI
    Quote Originally Posted by username
    i also read it that way too, i was just suggesting the obvious.
    USERNAME
    oh sure, claim you read it that way after i 'splain it to you.
    i hope he posts a follow up and let's us know what the heck the problem is/was.
    jackyd
    First 200 miles
    Sorry for confusion.
    I filled up a few times during first 200 miles with no problem.
    After the first few fill ups, problems began with fuel light and progressively got worse.
    Hoping it is a "stuck" float. Will let you know when I get time to work on bike
    Jack
    I had a similar issue on my GS. It turned out to be a faulty sender and was replaced under warranty. The dealer also suggested that pointing the gas pump nozzle into the right side of my tank can also force the float under pressure and damage it, then the calibration will be skewed. This may have been it too.
    Registered User glwestcott's Avatar
    Dec 2005
    Stockton, CA
    Quote Originally Posted by PUDGYPAINTGUY
    Ain't gonna be warranty on a 95. Damn
    BFish
    Jack
    turn it upside down and shake it. float may come unstuck. good luck.
    only kidding.
    jackyd
    You had me for .5 second
    Quote Originally Posted by Bfish
    only kidding.
    I started to look for an attachment that would explain how it easy it is to build a stand that would allow you to lift, turn over & shake the bike (warning tank should not be more than 1/2 full !!!)
    I'll try something more conventional
    Jack
    jackyd
    mystery solved
    Discussed problem of fuel light with mechanice at Mortons BMW, Fredericksburg Va. His first question was if a vacum could be forming in tank. Yes it could, when I popped the fuel latch a "swish" sound sometimes occurred.
    He suggested disconnecting fuel tank line to charcoal cannister (probably has an obstruction) until the line could be checked out.
    No fuel light problem since
    Jack
