J
Jfixit
The 2003 R1150RT comes with two accessory outlets on the left side of the bike, does it matter which outlet I use when charging the battery with a battery tender fitted with the BMW accessory plug?
PAULBACH said:It is all to easy to ground that metal tip. So I always plug in the jack to the plug and then plug in the Battery Tender.
