Results 1 to 15 of 20
Thread: tire pump
    tire pump
    Did one come with my bike originally? 1974 R75/6.
    Albuquerque, NM
    Yes
    Kent Christensen
    21482
    Here's one on my '71 R75/5 - If you have the mounting "nibs" shown, you should be good to go.
    If the pump mounts differently on the '74 /6, well then nevermind........
    ride what you've got; enjoy the ride!
    Turbo Fluffy Motoclub - IBA 50182 - BMW MOA 69187
    DAVIDSWANSON
    Is the BMW air pump servicable?
    the pump pictured looks alot like a Silca Bike pump. Is is basically the same and how long does it take to pump up a tire to normal inflation?
    thanks
    swanny
    Registered User MOTOR31's Avatar
    Aug 2006
    Full timr RV'er, where we park is home. No fixed address or location.
    It takes less time to pump up the tire than it does to get a tow truck or some tire service truck with air out to you........
    Just pump it up to about 26 psi and limp to a station if in town. If mot, just keep pumping until you're done.
    DEFINITION OF A VETERAN A Veteran - whether active duty, retired, national guard or reserve - is someone who, at one point in their life, wrote a check made payable to "The United States of America", for an amount of "up to and including my life."
    Author Unknown
    '99 '03 '06 National Co-Rally Chair Friedle's Avatar
    Poughkeepsie, NY
    pump
    Quote Originally Posted by davidswanson
    thanks
    swanny
    About 700 strokes ought to do it!
    Right after that you will be in the market for a small electric inflator.
    Friedle
    Ride fast safely
    Albuquerque, NM
    Quote Originally Posted by Friedle
    Very true.
    And, note that the 700 strokes won't happen without taking a break, because the pump will get too hot to hold.
    I carry CO2 cartridges.
    Kent Christensen
    21482
    Quote Originally Posted by rdalland
    I was wondering what those were for.
    I should probably get one, or see if the original owners still have it in their garage somewhere. A little pump is better than no pump.
    Grammarian no, Rider yes ISAMEMON's Avatar
    Jun 2006
    Kings Valley Oregon
    of course its not that easy if you have a spoke wheel,
    and a flat, that means dismount, patch tube and mount
    which is not as easy as it sounds
    at taht point, the number of strokes dont mean squat
    your still there for the rest of the day
    thats me waving at all the people driving by
    Aug 2006
    Took me far less than a day to fix my tire on my flat on my old R100. If it takes you a day, you really shouldn't handle sharp or moving machinery.....
    Author Unknown
    Albuquerque, NM
    Quote Originally Posted by Isamemon
    Carry spare tubes.
    You're supposed to use new tubes with every new tire, so you'll have lots of spares.
    Kent Christensen
    21482
    Jun 2006
    Kings Valley Oregon
    true I would not be there all day
    front would be fast
    rear a little longer adn a bit trickier
    I always install new tubes with new tires
    and I carry 2 of those little co2 cartridges that came with a patch kit
    "Enthusiast" King's Avatar
    Apr 2004
    Hudson, IL
    Yes, that is the pump that came on the 1974 R75/6. However, they were never practical for the reasons everyone has mentioned. They took too long and required too many strokes... and yes, they got hot. The last time I had a flat with a tube tire (early 1980s) I used a foot-actuated pump. If you want to restore your /6 to stock condition, by all means get one. If you want to carry a pump for emergency repairs, get a small 12 volt compressor.
    Don Braasch # 9049
    2003 K1200RS 1981 R100RS
    1974 R75 "S" 1977 R60/7
    I am eventually going to 'restore' it, one section at a time, because I can only aford a little at a time. Haha.
    To hijack my own thread: My subframe also has a clip on the opposite side of the pump, say... on the 'outside.' It's just behind where the shock mounts. (In comparison to that pic, it would be about straight in line with where that front weld is on the muffler.) Anyone know what it is?
    James.A
    I always thought it was for hanging your helmet. If you put the chinstrap through and then close the seat and lock it, it would be nearly impossible to make off with the helmet.
