Results 1 to 5 of 5
Thread: valve adjustment
    On the Road
    Dec 2005
    Lake Arrowhead, Ca.
    valve adjustment
    Could someone direct me to a post/site on the procedure to the adjust valves on a 1200 RT?? I would like to read the procedure before I start taking things apart. Thanks
    RIDERR1150GSADV
    Smile
    Simply put, it will and is identical to the 1150 bikes. Just the shape of the motor changed. For all practical puposes the internal changes are not even in view when the valve covers come off. YMMV
    Sanger, Texas
    Here's a link with some great pictures:
    http://www.advrider.com/forums/showthread.php?t=112324
    Braz J Brase's Avatar
    Jan 2005
    Central Indiana
    Oilhead Valve Adjustment for Dummies
    Registered User glwestcott's Avatar
    Dec 2005
    Stockton, CA
    Just to tell you not to be intimidate. Its even easier than the linked guides show. Buy a throttle synch device too, that's even easier to use and you'll be amazed at the money you'll save doing it yourself, not to mention the satisfaction you'll get. When its time to reline your brakes, if you've never done that, you'll find that a quick and easy job also.
