groeger said:Is it difficult to change the tires on a 2001 R1150GS? Also, how do you balance the tires?
Thanks.
lkchris said:Clearly you need a compressor and possibly a friend to help. It's a LOT easier to do this at waist level--like with HF changer--than on the ground.
Thanks.
GlobalRider said:Thats why some people get an old car rim (or new one) and mount it to a table top with the inside facing upwards. They then put that foam used on 1/2" copper water pipe around the edge of the rim to protect the wire spokes/cast spokes. A 1/2" threaded rod goes up the center that goes through the center of the rim and the nut pressing down on a piece of carpeted wood holds it all down in place.
Someone I know uses that set-up. Simple and cheap.
