Results 1 to 14 of 14
Thread: Valve Adjust - How cold is cold enough?
    25-MPH NEXT 1OO MILES PacWestGS's Avatar
    Aug 2004
    N47.06' 204" W122.33' 188" (PacNorthWet)
    I need to adjust my valves. Question - how cold does the engine (valves) need to be to get it right. I just got home two-hours ago and the engine is cool-to-touch. In the morning it will be garage temps of 45-50 degrees F.
    Should I wait?
    Doc
    Russ
    "If you took the time to really get to know me...you'd be wasting your time, because I'm exactly who you think I am"
    (Life comes at you pretty fast "Pay it Forward" - Have no regrets when the end happens)
    Registered User godfather's Avatar
    Oct 2006
    Cadillac, MI area
    I read the temp of the engine should be less than 90 degrees F.
    I will try to find the article and post it.
    Attitude is everything!
    08' V-Strom 650 great light weight tourer
    Still Wondering mika's Avatar
    Aug 2004
    Fly Over Land
    If the engine is lay your hand on it and leave it there warm you are cold enough.
    Aug 2004
    Thanks, be in the garage working...
    ciao
    Doc
    Russ
    Ambient is cold enough Russ, tough to be any cooler without parking in the fridge...lol.
    Aug 2004
    I'm done, top exhaust valves were a little tight on both sides. Now she's purring like a kitty. Valve adjust and throttle sync - ready to go for awhile again.
    Thanks Guys
    Russ
    Russ
    Has the GS-Lust The_Veg's Avatar
    Sep 2003
    Atlanta 'burbs
    Late to the discussion as usual, but my understanding is that the 'cold' recommendation is really sort of pointless. If thermal expansion is enough to throw off your clearances, then it would also be enough to cause serious problems with the simple operation of the engine. I've heard old-school airhead mechanics say that as long as they could do the job without burning themselves, it was good and remained so for a reasonable service interval.
    2012 R1200GS
    "If you can't fix it with a hammer, it's electrical." -somebody's dad
    http://www.thethingaboutcars.com/
    Scooter Trash WildWilly's Avatar
    Aug 2006
    SE Iowa
    Question Inquiry For SFDOC
    Who makes the crash bars on your GS? Thanks.
    Aug 2004
    Quote Originally Posted by wildwilly
    They're OEM BMW Adventure bars and skid plate. I added them becuase the bike should have them and they make the best "Highway Pegs" for the long haul.
    The Hepco-Baker bars probably protect better but I went for the comfort model insted.
    Doc
    Russ
    Quote Originally Posted by The_Veg
    This makes sense as the ambient is 120F in places where BMW's are sold and I don't see any recommendations for adjusting valves in an air conditioned room LOL...
    Not to be too irreverent, but lots of airheads developed a "reasonable" valve adjustment interval of 600 to 1,500 miles, because any longer than that and the exhaust valves might close up completely.
    Sep 2003
    Atlanta 'burbs
    Were those the receding ones or...?
    2012 R1200GS
    Not actually valve recession usually. Valve recession technically results when seats wear and the head of the valve sinks ever deeper and deeper into the worn seat.
    In the 1980-1984 models BMW installed new, hardened valve seats. And the valves often frequently closed up the gap on the exhaust valves. Shops would take the heads apart and find the heads of the valves deformed. Assuming the valves were bad (and they were by then) the shops replaced the valves. Since the seats looked pristine most shops replaced the valves and did nothing to the seats.
    After a few years BMW figured out that the seats were the real culprit. They were hard. They didn't wear. But they also were very poor at transferring hear from the valve heads. This is why the valves were overheating and deforming.
    When BMW introduced new seat metalurgy for the 1995 models they corrected the problem. And by then the shops knew they needed new seats as well as new valves to correct the problem on the earlier models.
    Sep 2003
    Atlanta 'burbs
    Right on Paul; I kinda though we were on the same page but I just wanted to be sure.
    My earlier point was merely about heat and metal rather than the hisotrical subtleties of airhead valves and seats.
    2012 R1200GS
