B
Bcpilot
I have a 2001 F650GS and want to install the BMW heated grips kit.
Has anyone done this? Want to know if its user-do-able. Thanks.
greggnj said:...but I installed the kit on my '03 F650. The tricky part is getting the heated throttle/grip wire in there without twisting or pinching it. You have to make sure when you slide the throttle onto the bar that the wire is in the correct position in relation to the cutout on the bar end, otherwise when you twist the throttle it will cut the wire-way down inside the grip where you can't fix it.
Ask me how I know
Even though I had to buy a new throttle for around $60, I'm sure I would have paid alot more for labor to have it done at the shop.
