grw
BMWNUT
fracture said:All of this makes me wonder if I should wait a bit longer and take a close look at the F800 when it gets here. I used to have my doubts about belt drive but since my Harley-riding friends are not reporting any problems, and I am not hearing of any problems, I might reconsider a bike with belt drive.
In over 20 years on airheads, the only drive problem I ever had was an oil leak on one bike. Has the new drive system gotten too complex to be reliable?
Having just sold my second Harley with belt drive I should let you know that all is not roses with belts. For twenty years I went down any damn road I pleased. I discovered the hard way that belt drive bikes should not be taken on gravel roads (exceptions may be bikes with elaborate belt guards).
I picked up a stone in 2005 on a 30 mile gravel ride and had to spend part of the winter disassembling half the bike to replace the belt. Nothing in Beemerdom prepares one for the stupidity of Harley's belt replacement process on the big twins (Sportsters may be easier). The belt itself is a $200 part plus you need about $45 in gaskets and locknuts. I did the work myself after discovering that two shops wanted around $700 to do the job.
OTOH the belt did not fail in service. It simply had a rock protruding through it about 2/3 of the way over to the edge. Rather than ride it until the belt unraveled or failed at that point I was told to replace it. I finally understood why Harley riders told me to stay away from gravel. Not good for the pocketbook!
I had to buy two special size sockets to remove the primary drive sprocket and clutch hub. There are a few steps in the process which are two person jobs (removing the swingarm and replacing same).
Good things about belts? No oil, no maintenance, quiet, well behaved, no driveline lash.
-Gary
