M
mayojuaf
My 2002 R1150RS with ABS has both levels at the minimum line (turned all the way right and checked and all the way left and checked)
I did the 12,000 service 10 months ago and rode just 1500 miles since then.
If I unscrew the top black boxes on the handlebars, will I be able to easily refill the containers to MAX without running much risk of screwing up something else? (getting air in the system or moisture or something like that?)
Do I need special tools?)
I do intend to take it to the dealer every 2 years to drain and replace all fluids, oil from engine and gear box etc.
Thanks in advance for your advice and help
